6.0 starting problems - Diesel Forum - TheDieselStop.com
Old 09-13-2009, 09:14 PM   #1 (permalink)
I have a 2006 F-350 with the 6.0 diesel engine in it. It started to sputter a bit, and now won't start. When I try to start it it sputters and puts alot of black smoke out the tail pipe. I had the codes read when it started to sputter and it claimed a low pressure problem in all 8 injectors and at the Turbo. Does this sound like the HPOP is bad, or is it the possible the IRP? Another suggestions let me know.
Thanks,
richkaysee is offline
Old 09-13-2009, 11:17 PM   #2 (permalink)
Could you post the DTC #'s?
Mark
bismic is offline
