6.0 stops and won't start again when hot
I've got a 6.0 2005 (F250) that did not want to start at all at first, no matter if it was hot or cold. I checked the ICP pressure, and it was only 400Kpa when cranking. I replaced the HPOP, IPR and ICP sensor, and now it's starting again, however, when it's getting really hot (after 20-30 mins of driving) the engine dies when the rpm goes towards idle. The only way of starting it again is to let it cool down.
I've monitored the ICP pressure when trying to start the engine (when hot), and i'm not getting above 1.5Mpa (ICP-DES = 4.5Mpa = no start).
I've installed brand new hpop and ipr, but perhaps one of them is bad - however, wich one? heeeelp
