6.0 Stumbles during start-up (fuel pump abbreviated) - Page 2 - Diesel Forum - TheDieselStop.com
Old 08-13-2011, 05:43 PM   #16 (permalink)
Lastly...
I've been looking at search results that come up via powerstroke.org...
For you engineers out there (or others), will/can the "diminished" ficm cause problems downstream to the injectors?
More specifically, should I bench my truck in the driveway until I fix the ficm? Or am I okay to drive it in the meantime? I'm hesitant, given the violent protesting (not to mention the black smoke) it exudes during start-up.
Double thanks,
John
hess77 is offline   Reply With Quote
Old 08-13-2011, 07:06 PM   #17 (permalink)
I have read that some Techs believe it can cause issues with injectors. I have seen no TSB or training literature from Ford that supports this, but I wouldn't risk it unless you just have to drive it.
I have used Ed at FICMrepair.com. His prices are VERY reasonable and he does very good work. SWAMPS is good also, just higher priced. I have heard the same about CircuitBoardMedics (being good also - not sure about the pricing).
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD Billet WaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is online now   Reply With Quote
Old 08-13-2011, 11:10 PM   #18 (permalink)
dieselmac's Avatar
x2 on what Bismic said! Park it.
Scott
2006 F-250 PSD, Lariat
Mods: All the usual stuff
dieselmac is offline   Reply With Quote
Old 08-14-2011, 09:11 AM   #19 (permalink)
Alright, thanks. FICM is out of the truck and into a box.
I decided to go with ficmrepair.com, I'll let you know how it all goes in the next few days.
Old 08-19-2011, 11:54 AM   #20 (permalink)
Went with ficmrepair.com
Ed was super helpful. He's taking the month off, from what it sounds like, but still managed to send me a rebuilt unit same-day. Put it in this morning, and the truck runs like a champ!
Also upgraded the fuel regulator spring and replaced the fuel filters while I had it apart.
Got a scan gauge ii like you guys recommended. I'll try that out today.
Thanks to all who responded, made my life a lot easier!
Old 08-19-2011, 01:06 PM   #21 (permalink)
Your egr cooler might not be leaking itself but the little coolant hose used to connecting it. It has a quick connect style connector with a o-ring on one side. This was where mine was leaking.
macmaniac1 is offline   Reply With Quote
Old 08-20-2011, 02:20 PM   #22 (permalink)
lowblues's Avatar
Hey! Did your check engin light come on during any of this? I'm having a lot of the same issues but the check engin light is on as well. Mine is a 2007 6.0 motor.
Andy
2007 F350 crew cab. Lariat Package SRW and 8' box
Firestone Ride Rites
lowblues is offline   Reply With Quote
Old 08-21-2011, 12:17 PM   #23 (permalink)
iwejun's Avatar
Just had my FICM replaced on Friday same conditions were happening in addition, mine would idle with no response from the pedal when I pushed down, then suddenly I would have pedal and it would drive fine. For a while.
07' 6.0 Lariat,350, DRW,CC boney stock (not anymore)
Pullrite Superglide, Sandpiper 32BHSS Platinum
2007 Four Winns 224
" LET'S ROLL !" Todd Beamer-Flight 93
Dieselsite Coolant Filter
BulletProof EGR
BulletProof remote oil cooler
MagHytek Rear Diff. Cover
HID Headlights
All LED lights inside and out
BullyDog GT2
MBRP 4"
DC Power 270 amp
iwejun is offline   Reply With Quote
Old 08-22-2011, 07:12 PM   #24 (permalink)
No, I never had a light come on.
It's really quick to do the simple voltage test. All you need to do is pull the coolant reservoir out of the way with to 8mm bolts, pull the cap off the ficm (torx t-20 if I remember), and do the quick test with engine off and on.
*Clear warnings all over the place not to touch the voltmeter to the side when testing, it's like playing operation.*
My voltage was ~ 1/2 what it should have been, no check engine light.
Also, I picked up a scan gauge ii from Amazon for about 150 shipped. I have yet to find a code, but that might help you identify any other issues you might be having that trips the engine light.
Old 11-17-2012, 04:13 PM   #25 (permalink)
Here it is winter time again, cold starts inevitable. I have an '07, 250 diesel, mornings are spent coaxing the 6.0 to life. I also like Hess77 am intrigued by the injector buzz. Some mornings i hear it other times I don't, hence hard starts. I thought it was glow plugs so Changed Glow plug relay with no improvement. Now have new fuel pump and ready to install but don't know if this is the fix either. Have read a lot of references to the FICM but videos do not duplicate my problems. Speeds above 70 mph truck seems to miss or cough black smoke. These symptoms do not appear in warmer weather. oil filters, air filters and fuel filters done regularly. Rotella T 15w40 used all year. Have had multiple issues with water in fuel treated with Diesel 911 and filter changes. Truck has 150,000. Any help?
TIA.
richf27 is offline   Reply With Quote
Old 11-17-2012, 06:52 PM   #26 (permalink)
Ford recommends NOT to use a fuel treatment that contains alcohol. Diesel 911 contains alcohol last time I looked.
Mark
Old 11-17-2012, 07:27 PM   #27 (permalink)
This sounds alot like the probs my friend is having with his truck.
He complains of his truck starting hard and running rough in the morning.But when is warms up he says in runs good the rest of the day.
So could this be his FICM going bad.He's already had it replaced once about a year ago.
If anyone has a tech in the Tampa area he'd appreciate it.He doesn't work on his stuff so he'll need alittle help getting his truck fixed up.
2011 f350 4x4 cc,Lwb
mopwr is offline   Reply With Quote
Old 11-20-2012, 02:43 PM   #28 (permalink)
stiction. run some Hot Shots secret in the motor oil...... Did the FICM already....
97 F250 PSD Xcab 4X4 rebuilt trans,precision converter, tugger shift kit, hughes pan,4" bigboar exhaust. 3 gauge pillar, trans,pyro,boost. add a leaf 260,000 miles 06 F250 Xcab 4X4 powerstroke, juice with attitude that is junk. 140,000 miles, 5 " Diamond eye redneck Fartpipe with cat. rolling on 20" grapplers. Gone but not forgotten, 04 Cobra Mustang. Better known as the Corvette Killer. 2.93 pulley, 438/466 HP/TQ.
scootdog is offline   Reply With Quote
