6.0 Throttle Position Sensor - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 06-08-2006, 08:09 AM Thread Starter
I have a 2003 6.0 and the throttle pedal has about 1/2in to 3/4in travel at the top that nothing happens.. When bringing it off idle
it takes a lot of pedal movement be for rpm's go up.. when driving
under 15MPH it seems that the engine rpm's jump around (surge).. anyone have any ideas?? needs a new TPS?? I can't see any ajustment
for this in the reostat.. HELP!! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Lonnie
2003 F350 DRW 4X4 Lariat 6.0L
2002 F350 SRW 4X4 Lariat 7.3L
1998 Lincoln
1997 Dakota 4X4 SOLD
1996 Ranger
1986 Corvette Caught Fire IN Garage
17' Bass Tracker
2003 Montana BigSky 5th Wheel 3 slides
SkipBo00 is offline
post #2 of 2 (permalink) Old 06-08-2006, 11:01 AM
Re: 6.0 Throttle Position Sensor
There is no adjustment. The TPS has three sensors. Two are identical and the third is an exact reverse of the other two. If one sensor goes bad it will throw a code, but the pedal still works. If two go bad, it will limp home.
Mine has a little play at the top too. I have not put a tape measure on it, but I could guess it is about a half inch. It bugged me at first, but now I don't notice it.
My dog freaks out and shys away from anything new in his world. I moved my bar-b-q this weekend and he would not go out on the patio. He's only 4 months old. This is normal. When he grows up I expect him to handle things he's never encountered before a little better than he does now. <wink>
Nate
2006 F350 PSD Crew Cab, Short Box -
MODS:
I wired my radar detector into the #4 upfitter switch.
Valley Slider, full articulatioon 5er hitch.
Layton Rampage 289 - two ATVs - Box of firewood - full tank of gas...what else ya need?
stuckinthemud is offline
