Hi guys I have a question, on Sunday my 6.0 would not start at all.. My neighbor and I did a few things, we traced the lines, checked the fuel lines and pump. It still would not start. Fuel was flowing when we removed the cover to the fuel filter on top of the motor.
I released the fuel filter on top of the motor and cranked it, some fuel spilled. I then closed back up and it started immediately. My friend thinks I have an air bleed some where. I checked the o-ring and it was fine, I applied to Vaseline and re-closed it.
Today I' having more problems starting. I cycle the switch 3-5 times and it starts!
Any Ideas? Should I change the fuel filter cap? change the o-ring? although it looks good.
Another thing to note is, the oil pressure needle does come up while starting after a couple of seconds.
Thanks,
Ed
