6.0 Weird Start Up Behavior - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 10-26-2012, 10:24 AM Thread Starter
mkb1314's Avatar
See if y'all can help figure this one out...
This is on my 2005 Excursion. It's kept in a garage at night. Temperatures down here have been high 80's during the day, high 60's at night so it's definitely not cold starting conditions. This issue has just started within the last couple of days when she goes to start it in the morning.
Spits and sputters upon start up, runs rough. Within 20-30 seconds, definitely under a minute, motor smooths out and runs fine.
Since it smooths out and runs fine very soon after start up, I'm at a loss as to what it could be. This truck / engine has been virtually trouble free for its ~105,000 mile life so I'm not really up to speed on what 6.0L issue it could be.
Thanks in advance!
2002 F-250 XLT, SC/SWB, 4x4/Off-Road Pkg., PSD/6 spd., 3.73 LS, True Blue Ext./Medium Flint Int., Ford Aluminum Wheels, Captain's Chairs, Factory Tint/Sliding Window, Manual Hubs/Manual X-Case Shifter, Banks Stinger, Cyclone Fan, Line-X bedliner, chrome bedrails, Tymar Intake, ATS Compressor Housing, Bilstein Shocks, LT285/75R16 BFG AT's, DP Tuner F5 Chip
2005 Ford Excursion, 6.0L, 4x4, Eddie Bauer Edition with ALL the bells and whistles, white / tan two-tone, stock for now! ***SOLD***
1974 Bronco with a very worn out 302 w/Edelbrock intake and 4 bbl. carb and converted to electronic ignition, 3 spd. on the floor, Koenig Iron Works PTO winch, 33x12.50x15 Cooper STT's/15x10 chrome rims, true duals, a couple of whiskey dents and drunk bumps, and of course, the kicker...OEM RETRO NEON GREEN PAINT ***SOLD***
mkb1314 is offline
post #2 of 3 (permalink) Old 10-26-2012, 10:52 AM
fordsforever73's Avatar
My Photos: (24)
Feedback Score: 2 reviews
Do you have any way of checking codes? That would be the first thing to do. It's really hard to say what kind of problem there is until certain things can be ruled out. Could be anything from low HPO (High Pressure Oil) to injectors, low voltage at FICM (Fuel Injection Control Module), glow plug issues, etc.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. FICM by Ed with Atlas 40 tune, DC Power 185 amp alternator, MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. +More.
fordsforever73 is offline
post #3 of 3 (permalink) Old 10-26-2012, 03:41 PM
I would start here.
One other thing keep good batteries in it because there are a lot of FICM problems coming up with all of these trucks that have old batteries.
or--- http://ficmrepair.com/ My choice
Info here
http://swampsdiesel.com/site/install...ge_Testing.pdf
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
