6.0L Fuel Filters - Description of Symptoms when clogged
This past weekend I was bombing across the desert when I noticed a mild drop in power. Since it had been raining for an hour I figured that the air filter had become soaked and was not flowing as it should. Few minutes later the power dropped further and the truck slowed from 70mph down to 60mph, it simply would not go over 60mph. Now I’m thinking that maybe one of the turbo hoses has blown off. Pulled over at a rest stop in the pouring rain, popped the hood so I could check the turbo hoses, checked the motor and trans for excess heat, everything OK so I continued down the road to the next town. The motor felt like it was not breathing or not getting enough fuel.
While driving to the next town I looked at the mileage, 74960 miles, my extended warranty expires at 75000. How convenient! Still the truck could not get over 60mph, by the time I reached the next town the rain was gone. This time I was able to tear down the air box and validate that it was not soaked, flowing fine. Decided to remove the two micron filter mounted on top of the motor, all you need is a ½ inch ratchet.
The filter was very dark in color, clearly it was white in color when new. Tried to blow some air through it and discovered that it was more than restrictive.
Just so you know – the motor will only run for thirty seconds without a filter. The filter is used to open a valve/trap that allows the fuel to move into the motor. Stabbed the filter with a ball point pen, buttoned her up – the truck has never run better. Replaced the filters once I got home. The filters had never been replaced.
Re: 6.0L Fuel Filters - Description of Symptoms when clogged
Good symptoms. Warranty is worhtless in this case with 74000+ miles. The owner's manual says to replace the fuel filter every 15000 miles. You would not have a leg to stand on in this argument. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
__________________ 2004 Ford F350 Crew Cab 4WD Lariat 6.0L PSD Torqshift SRW Med Wedgewood Blue / Arizona Beige
Tuff Country 1.5" Leveling Kit ... Hardcover Tonneau
Pro-Flap Mud Guards ... Toyo M55 LT285/75R16 Range E
GOS Racing Headlight Harness with Silverstar bulbs
Factory Ordered and Delivered: Feb 7, 2004.
<movieshow2003 at yahoo.com>
Holy cow!!! [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] You ran the same set of fuel filters for 75,000 miles???? [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
I felt bad about letting mine go the full 15,000. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
__________________ 2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
Tks. for info. interesting. Often wondered how long f/f would last. At least you got it going/made it back. Off topic... but my old 88 F250 w/460 had over 70K before I changed orig. f/f.
Maybe there's something to what a local fuel driver told me. In our area, in ground tanks were being made out of fiberglas (no corrision/gunk build up?) & good filtering system. Maybe same in areas you travel to get that long f/f service. Maybe change alittle sooner next time. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
OT [img]/ubbthreads/images/graemlins/smile.gif[/img]
I hope you didn't fill the injectors full of dirt from poking a hole in the filter. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
