6.0L glow plug check - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 10-10-2012, 09:52 AM Thread Starter
i am getting 0.0 ohms checking each of my glow plugs at the connectors at gpcm. i have a 2006. i have seen where a high reading means bad glow plugs what does no resitance mean? help
broomfieldj is offline
post #2 of 13 (permalink) Old 10-10-2012, 10:05 AM Thread Starter
i am using a fluke meter so i am sure of the readings
post #3 of 13 (permalink) Old 10-10-2012, 10:44 AM
rock_doctor's Avatar
Don't worry about it. If you have a bad glow plug it will set a code and will tell you which cylinder is bad. If you do have one bad then I would change them all since you have the wheel liners out and the plugs are cheap enough, about $10 each. "0" resistance means it is an open circuit, so one of the probes is not making a good connection, probably your ground to the block.
rock_doctor is offline
post #4 of 13 (permalink) Old 10-10-2012, 10:58 AM
RatherBNtheWoods's Avatar
I'm not certain that glow plugs are monitored individually. I do think they are powered in parallel per bank, and I know 0 ohms is a short, not an open.
Each bank will draw 150-200 amps when cold, so there isn't much resistance there. Maybe you didn't get absolutely 0, just a small r4eading and thought it to be 0. Use the old r=e/i
Have you a clamp on ammeter to go with your fluke mm? If so, reading current will tell you.
ps: If it were actually 0 ohms, the glowplug module would fry and then you would get a code.
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
post #5 of 13 (permalink) Old 10-10-2012, 12:11 PM
It will set a code for a specific plug. I had a #7 code at the beginning of the summer. Changed them all, not bad once you get the plastic wheel liners out.
post #6 of 13 (permalink) Old 10-10-2012, 07:57 PM
dieselmac's Avatar
And it's only ~10amps per GP.
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #7 of 13 (permalink) Old 10-10-2012, 08:44 PM
jeffws's Avatar
Mine set a code for #2 - I replaced #2 and the code was still there. I checked the harness and it was good. Replaced the GPCM and that fixed it.
05 F 250 CC PSD FX4
BPD EGR Cooler
DC Power 185 amp
Dieselsite Coolant Filter
Edge Insight CTS w/ Fuel Pressure, EGT and Turbo Timer
Blue Spring Upgrade
HFCM Water Separator Drain Plug Upgrade
High Idle Mod
Mag-Hytec 6 Quart Diff Cover
Bilstein Shocks & Dual Stabilizer
285 75 17 Toyo's
Airlift Air Bags
jeffws is offline
post #8 of 13 (permalink) Old 11-03-2014, 02:59 PM
Hey Guys,
Hey Guys,
I went from all is fine starting to having to plug in the block heater to get it start on a warm day. I since put it on a code reader and it says 1-8 low voltage code or something along those lines. I would think with all of those codes, it might be something else? Anyway to find out prior to pulling the wheels etc?
Thank's
Billy H. is offline
post #9 of 13 (permalink) Old 11-03-2014, 03:08 PM
dual post...
Billy H. is offline
post #10 of 13 (permalink) Old 11-03-2014, 04:08 PM
drcampbell's Avatar
My Photos: (32)
Originally Posted by RatherBNtheWoods View Post
... Have you a clamp on ammeter to go with your fluke mm? If so, reading current will tell you. ...
Many clamp-on ammeters measure AC current only, and will indicate zero no matter how much DC current is present. Make sure you know what your instrument is capable of.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
- Never did get around to converting it to french-fry oil, which is why I originally stumbled upon this site.
drcampbell is offline
post #11 of 13 (permalink) Old 11-03-2014, 04:41 PM
Clamp on Ampmeter
The one I borrowed only does Ac, so it's worthless.
Billy H. is offline
post #12 of 13 (permalink) Old 11-03-2014, 04:45 PM
I did have the initial #8 cylinder code pop up and two weeks later, all of them. I am guessing it's the GPCM. Be difficult to believe it would be the harness's and all the plugs at once. The truck runs great when it warms up, it's a bear to start cold and it run's like crap!
Billy H. is offline
post #13 of 13 (permalink) Old 11-03-2014, 05:18 PM
For all to go out at once if it is not a wireing issue then it is the module.
dannyboy950 is offline
