6.0l head interchange - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 10-27-2009, 12:19 PM Thread Starter
I have an 04 6.0l powerstroke and would like to know what year model heads will work on my truck.I have a set of 06 heads but I am not sure if they will work.Thanks for any info you can give me.
outlawpony is offline
post #2 of 5 (permalink) Old 10-27-2009, 03:15 PM
do you have a round or rectangular egr cooler?
6.0 tech is offline
post #3 of 5 (permalink) Old 10-27-2009, 04:19 PM Thread Starter
it is a late build it has rectanglular egr, but the part number for 06 is diff than the 04 late build with icp in the valve cover
post #4 of 5 (permalink) Old 10-27-2009, 05:25 PM
teamroper60's Avatar
Later 06 & 07 heads are slightly different than the early 06 and previous years. Here is a rundown of the changes:
Subject: 2006 6.0L Diesel Power Stroke Cylinder Head Commonization
Effective Date: Ford Production Assembly Plants - January 11, 2006
Kentucky Truck Plant (Super Duty) & Lorraine Assembly Plant (Econoline)
Description
Changes are being made to the 6.0L diesel cylinder head, head gasket, crankcase block, rocker
arm carrier and injector hold down clamps for the 2006 Super Duty and Econoline Program. The
action is taking place to facilitate/communize the International manufacturing process for the
upcoming 6.4L program. The 2006 6.0L used in Ford vehicle after January 11, 2006 are being
referred to as "Commonization Engines".
Part number details are provide on a separate excel spreadsheet.
Cylinder Head:
New cylinder head
1. Carrier boss bolt holes M10 x 1.5
2. Injector clamp bolt holes (relocated)
The new cylinder heads have several casting changes including a slight injector clamp bolt hole
relocation and the carrier boss bolt hole size and location changes . New
cylinder heads also use 32 mm cup plugs replacing the old 28 mm cup plugs.
The cylinder head gasket is also new to accommodate the new 20mm cylinder head location
dowels. Pre commonization head use 18mm dowels
Note: At this time the new cylinder head assembly is not interchangeable with the previously level
head.
Previous Level Cylinder Head
1. Carrier boss bolt holes M8 x 1.5
2. Injector clamp bolt holes (original locations)
Note: The previous level cylinder head assembly is not interchangeable with the new head.
Block Assembly:
New Block Assembly
The new crankcase (block) uses two 20mm cylinder head locating dowels per head.
The old crankcase (block) uses two 18mm cylinder head locating dowels per head.
Note: The new and old block assembly is not interchangeable. This affects replacement of all 6009
short blocks and the 6010 bare blocks.
Rocker Arm Carrier:
New Rocker Arm Carrier
Casting changes to the rocker carrier provide increased clearance for new injector hold down
clamps The new carrier also uses only 2 bolts and locating dowels to attach the carrier
to the head.
The new rocker carrier is serviced in a Rocker Arm Carrier Kit which includes the rocker carrier
cover, gasket and necessary dowels.
Note: The new and old rocker arm carrier kits are not interchangeable.
– Previous Level Rocker Arm Carrier Kit
The old rocker arm carrier uses 4 attaching bolts to hold the carrier to the old cylinder head
The previous rocker arm carrier is also serviced in a kit which includes the rocker carrier cover,
Note: The previous level rocker arm kit is not interchangeable with the new kit and will remain
available for service.
Injector Hold Down Clamp:
New Injector Hold Down Clamp Assembly
The tail end of the new injector hold down clamp is being reduced to avoid interference with the
rocker arm carrier wall. Injector hold down clamp bolt torque will increase from 24 lbf·ft to 25.8 lbf·ft
and bolt head size will increase from T40 to T45.
Note: The new and old injector hold down clamps are not in interchangeable.
– Previous Level Injector Hold Down Clamp Assembly
Note: The new and old injector hold down clamps are not in interchangeable. The old injector hold
down clamp will remain available for service.
A new service cylinder head kit that will work on the previously engine block will be released for
service in the near future. The new kit will include stepped dowels (20mm/18mm), the new cylinder
head (with the new carrier assembly), a cylinder head gasket kit, early level standpipe and an
instruction sheet.
The head will be available for dealer to purchase when the existing supply of earlier level new
heads are no longer available.
You can take that information and do some measuring to see if those 06 heads are of the older or newer, "commonized" variety.
#43
President and Webmaster
teamroper60 is offline
post #5 of 5 (permalink) Old 10-28-2009, 07:52 AM Thread Starter
thank you for the info teamroper
