6.0L long crank time - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 08-29-2011, 08:58 AM Thread Starter
Hey there...I have an 07 F250 wih 90k on it....it was cranking for 15 to 20 seconds...ford did an update on the pcm and it cranks for 5 to 6 seconds now when cold and 3 to 4 seconds when warm......its been in the shop for 5 weeks off and on this summer....ford replaced a wire harness on the hpop....then something on the IPR and still cranks for a long time.......one day I cranked it for over 2 minutes even after it was warmed up and had been shut off for 10 minutes.....im looking for any suggestions to tell the ford dealership cause they obviously don't get it
hempdaddyshane is offline
post #2 of 18 (permalink) Old 08-29-2011, 05:35 PM
I just fixed my leaky STC fitting and my crank times are now back at 1-1.5 seconds whether hot or cold.
I had the infamous 'No Start Hot' failure at Carl's Junior, forcing me to have the vehicle towed home....I'm ecstatic that it failed 3 miles from home, instead of 100. I spent the last 2 weeks repairing all the known issues, other than putting in head studs.
I read on one of the forums that they bought a new HPOP and it still had the STC fitting on it.
Based on my experience, I think you should press Ford for whether or not your vehicle has the STC fitting. If it does, I believe it's a matter of when it will fail, not if.
Just my 2 cents, after spending 6 years waiting for this failure mode and it finally happened. If I had not read about it so extensively on the forums I would never have attempted to fix it myself. I got the run around from Ford for 5 years and eventually determined that the Warranty was useless for this particular failure because the symptoms are so marginal. The Dealer was able to argue, in my case, that they are not conclusive. I had cold start issues (white smoke) that I believe are related and will prove to myself this Winter one way or another. Nonetheless, I hope this is helpful information for you.
bustedknuckles is offline
post #3 of 18 (permalink) Old 08-29-2011, 07:42 PM
Piros1's Avatar
Piros1
I was always told that there is no dumb question but I may have one. What is a STC fitting and where is it located on the engine. I am a fair hand with a wrench but these newer electronic diesel engines with there HPOP operated injectors are new to me but I have not one 6.0 but two 6.0 diesel engines. One is in my 2005 Excursion and one in my F350 King Ranch duelie. Thanks.
Piros1 is offline
post #4 of 18 (permalink) Old 08-29-2011, 08:54 PM
dieselmac's Avatar
It stands for snap-to-connect fitting. It connects the HPOP to the branch tubes and is prone to failure. Complicating matters, a leaky STC fitting does not give any external, visual clues. It's all internal to the oil system.
Here's a couple good articles:
DTS Articles - New High Pressure Oil Connector
DTS Articles - 6.0L ICP System Leaks
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #5 of 18 (permalink) Old 08-30-2011, 04:42 PM
Piros1,
If your going to fix the STC fitting issue, be ready to do a lot of other things while your in there. I say this because the cost of the work is mostly labor. If your doing it yourself, you might say it's you own time, so it doesn't matter. But after doing it, I definitely am glad I did everything at once. I wouldn't say it was real difficult, but it was a time consuming job; one which I don't want to do again for a long, long time.
I did the following:
Rebuilt oil cooler
Replaced EGR cooler with the the one from Bulletproof Diesel
Replaced my water pump
Replaced my serpentine belt
Replaced my dummy plugs and stand pipes
I'm hoping I don't have to open up the engine again for at least 100,000 miles.
I may need some injectors, but this will be a significantly smaller job than what I just did.
You asked what the STC fitting was.....as dieselmac said, it connects the HPOP to the branch tubes, which feed the high pressure oil to your heads, which in turn supplies the injectors. A good way to describe this fitting is to compare it to the fitting on a compressor air hose, only this hose sends 4,000 psi oil to your injectors. It was really silly for International Harvestor to even use this fitting. It's flaky. The repair is to replace the connector, that has this fitting, with a different style connector that doesn't even have the STC connector. The new one is a straight metal pipe.
post #6 of 18 (permalink) Old 08-31-2011, 06:44 AM Thread Starter
Ok, so im sure its the stc fitting thats causing my long crank time but is there a sure way to test it without tearing into the motor??? The ford dealership has been working on the truck under warranty but I think they don't want to tear into the motor because its going to be time consuming and there backed up for weeks and don't want to tie up a rack for that long. Another question...I read where the replacement stc fittings are metal....so did international ever use the metal fitting cause my truck was the last year for the 6.0?
Thanks for all the responses guys....
post #7 of 18 (permalink) Old 08-31-2011, 10:43 AM
mountie's Avatar
My Photos: (6)
Wonderful. Like we don't have enough things to worry about with our 6.0. May as well as add this to the list. Thanks for the heads up.
2007 F350 crewcab Lariat shortbox Diesel 4X4, Retrax Roll Top Cover, Newer tailgate with camera and step, Airaid Intake, Magnaflow exhaust, Cortex tuner on mileage setting, Edge Insight CTS Monitor, Upfitter Switch Kit, Sinister Diesel Coolant Filter. Warn 12000lb Winch with Stainless Transformer setup and a pair of 150 Watt Stainless KC Daylighters. Ford Blue Spring Fuel Pressure Regulator Upgrade Kit. 200 Amp Alternator.
mountie is offline
post #8 of 18 (permalink) Old 08-31-2011, 02:48 PM
Wait a minute...even if the failure symptom is that your high pressure oil system is not reaching the required pressure, there is more than one possible cause for this.
If you want to be reasonably sure, you can temporarily remove the ICP from the passenger side valve cover and connect 'shop air' (air compressed to 80-100 psi) to the ICP port. You need to command the IPR on so it closes, otherwise the air will simply flow back through the valve and into your crank case, giving you inconclusive information. There are a few descriptions of how this is done in the forums. I'm not an expert on doing this test, however, from what I've read, if the leak is coming from the STC fitting it will sound like it is coming from the oil input tube...if it is your stand pipes or dummy plugs you will hear it coming from under the valve covers....more toward the front of the motor.
Like I said, I'm not an expert....just trying to point in the right direction.
I replaced the branch tube fitting (fixes the STC fitting) with the newer one and did both dummy plugs and standpipes as well. It was worth it to me to know that most of the common potential sources of leaks were fixed with the latest improved components. The new stand pipes and dummy plugs have a better o ring system (a spacer that helps improve the sealing pressure), and the new branch tube eliminates the STC fitting entirely.
post #9 of 18 (permalink) Old 08-31-2011, 07:48 PM
Piros1's Avatar
Thanks for the info I will keep track on this post. when I find out what is wrong with my6.0 I will post the details.
Piros1 is offline
post #10 of 18 (permalink) Old 09-01-2011, 04:48 PM
I don't know this first hand, however, I think I read on one of the forums that International recalled all their vehicles that used the STC fitting. Ford chose not to do a recall. This was most likely a financial decision that has cost them much embarrassment.
post #11 of 18 (permalink) Old 09-13-2011, 07:40 PM Thread Starter
Ok, so finally after 6 trips to the ford dealer and 2 long summer months they fixxed my truck.......the mechanic who finally fixxed my truck only works on saturday and I picked it up on sunday so I didn't get to ask him what he found exactly but the paper work said this the "verified concern, performed diag and found codes p0336, found low ICP after engine warmed up, performed air pressure test and found right side block off tube leaking, replaced and rechecked all ok"
Does anyone know what that code is?
what is low ICP?
what is the right side block off tube?
Thanks...shane
post #12 of 18 (permalink) Old 09-14-2011, 08:24 AM
I suspect he means the O ring on the high pressure rail failed - had the same thing on my truck.
2011 F350 SRW King Ranch
rcgreg is offline
post #13 of 18 (permalink) Old 09-14-2011, 04:35 PM
Another more common name for the block-off tube is the dummy plug.
I just replaced mine with the latest upgraded stand-pipes and dummy plugs. I also fixed the STC fitting (replaced the branch tube with the upgrade, which does not have an STC fitting); I believe my long start, and ultimately, 'No Start Hot' issue was the STC fitting.
In my opinion, if you haven't fixed the STC fitting on your truck your just waiting for it to get bad enough to see symptoms.
My truck takes no more than 1.5 seconds to start, now that it's fixed, whether it's hot or cold. This is what it did new and it's now back to starting reliably again.
post #14 of 18 (permalink) Old 07-08-2013, 05:33 PM
Question Help on P0336 code
Does anyone have any detailed info/pictures on the fix "bustedknuckles" did on his truck?
jayhawk714 is offline
post #15 of 18 (permalink) Old 07-08-2013, 06:58 PM
dieselmac's Avatar
Search YouTube for "STC Fitting" or "6.0L Standpipes". There are several good videos.
Scott
