6.0L Powetroke Wont Start - Diesel Forum - TheDieselStop.com
Old 03-28-2009, 07:44 PM   #1 (permalink)
I have a 2003 F-350 6.0L Powerstroke that has never really given me any problems at all. The majority of the time it will start but recently ever once in a while it wont. Now if it wont start for me i leave it sit over night and then it will start fine in the morning. It really has me baffled! Any suggestions would be greatly appreciated!
DirtyDeez09 is offline
Old 03-28-2009, 08:57 PM   #2 (permalink)
ZMANN's Avatar
glow plugs??
O6 King Ranch cc sb 4 inch lift ,35 Pro Comp,Helo’s Edge Insight CTS guage only , Auber EGT , o8 center console ,2x10 subs, xm satellite ,coolant filter,RSX 9000 shocks,dual bilstein steering stabilizers ,Viper , remote toolbox popper, High Idle mod , up fitters added ,weather guard mats , ARP's, BPD EGR cooler, Marinco Mod ,Zoodad waste Fabtech traction bars, Some other stuff
ZMANN is offline
Old 03-29-2009, 01:07 AM   #3 (permalink)
As far as i know they are good. They havent given me any trouble up to this point unless they are going bad. But i still dont understand why it would start some of the time and then some times it wouldnt. What would letting it sit overnight do that would make it start right up the next day as if nothing was even wrong?
Old 03-29-2009, 01:05 PM   #4 (permalink)
Jimn8or's Avatar
Do a search on 'won't start' or 'no start' and behold the plethera of info that appears. I would bet you have an issue to do with oil. Hi pressure oil pump, Internal pressure regulator fittings fubar that haven't been updated as per Ford etc...Do a search and you'll see that you are not alone with this problem. Make arrangements for other transportation till Friday if you have a Ford Dealer that knows what they're doing.
HTH
Jim
2006 CC SD SB PSD
Jimn8or is offline
Old 03-30-2009, 07:27 PM   #5 (permalink)
I have had my hi pressure oil pump replaced not that long ago. Is it a possiblity that it went bad that quickly? It probably hasnt even been half a year since it was replaced. I really would hate to buy another one..... It was really expensive!
Old 03-30-2009, 08:24 PM   #6 (permalink)
My money is the oil pressure sensor. Is your no start issue after it's been running? Commin headace see earlier post. The vehicle needs something like 400 psi of oil pressure to start, but the sensor faults and will not allow the engine to fire. If you scan the computer, you would find excecss cranking code.
Paul J is offline
Old 03-30-2009, 08:29 PM   #7 (permalink)
I have a 2006 6.0 that is using antifreeze 1gal in 2 weeks is it the head gasket what should i do
red676 is offline
Old 03-31-2009, 10:42 AM   #8 (permalink)
Red,
Welcome to TDS.
It would be good if you could use the search feature for about the last 3months. Look for head gaskets, puking, & antifreeze. If you don't find anything (but you will) try a new post, so you don't hi-jack this one.
It's also a good thing to add your vehicle and any/all mods done to it to your signature line so we don't have to ask more questions to help you out.
So - do you have any indication of coolant puking out of the degas bottle? How's the level in it? Any white smoke?
OMC
OMCUSNR is offline
Old 04-01-2009, 12:33 AM   #9 (permalink)
High pressure oil leak my friend. Odds are you arent seeing any oil on the driveway either.....or just tiny drops if you go check.
The truck gets to a certain temp, and the pressure leak causes it to not start while hot. Let is sit for a few hours and it starts? Definately a high pressure oil leak.
2004 6.0Powerstroke ExtraCab. Indigo Blue over Tan, Super Chip, AT's
2007 6.0Powerstroke CrewCab. Silver, Chrome package, SuperChip, MBRP Cool Duels Turboback
Burper/Puker
2 Degas Bottles, 3 Degas caps, 1 EGR Cooler, 1 Oil Cooler, 2 O-rings.....still puking.....
Also, two speed sensors, and about 13 damn tail light bulbs.....
StrokinTiger is offline
Old 04-01-2009, 12:34 AM   #10 (permalink)
It will not code with a high pressure oil leak. My money is on that and not the sensor, as stated in my post above.
Burper/Puker
Old 04-01-2009, 03:38 PM   #11 (permalink)
Yes my problem does seem to be after it has been running for a long period of time. Like if it is just short distances and not run that much or hard it seems to be fine but if its a long distance it is then that i have the problem. Thats what it seems like to me anyways.
Old 04-01-2009, 03:58 PM   #12 (permalink)
NU2Diesel2006's Avatar
Dirty,
like Strokin said, high pressure oil leak. The fittings inside the engine have probably come loose. If you search on HPOP issues you should find something about this.
Laurier
2006 F350-Lariat, CC/SB 4X4 SRW-Wedgewood blue
6.0L PSD, Auto, 'with all the goodies' except the moonroof, born 23/3/06
BCP mod-switch #4, CAC tube secured
Zoodad
LEER Canopy and Chrome stepbars, Draw-Tite 18k Signature Series hitch
Line-X bedliner
Sirius Satelite Stereo
Alarm/Remote start
2000 26 ft Frontier Plainsman fiver - 11k loaded
Looking to add LCD monitor/gauges, back up lights and intake elbow soon
NU2Diesel2006 is offline
Old 04-01-2009, 05:41 PM   #13 (permalink)
paintingman's Avatar
One thing you can test is your batterys with a load tester one at a time to see if one or both are holding a charge or not. Mine was slow starting and some time would not start after replacing both batterys and alternator it starts right up. over time you can't hear or notice the starter spinning slower and slower.
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
Old 04-01-2009, 06:16 PM   #14 (permalink)
If it was the HPOP would it start off of starting fluid or even wd40?
HARLYBO_8 is offline
Old 04-02-2009, 10:06 AM   #15 (permalink)
No. The HPOP is what is used to provide "hydraulic" pressure to the injectors. W/out it, there's nothing to open them.
OMC
OMCUSNR is offline
