6.0l problem after problem - Diesel Forum - TheDieselStop.com
Old 03-22-2009, 01:39 PM   #1 (permalink)
Had the EGR replaced, crank sensor replaced and recalibrated, front bearings 3 sets, broken parts in the fuel system and now a high pressure oil pump. 3rd set of batteries, new alternator and still the same problem. The Ford dealer has no idea because the computer reads fine. If I leave it for 2 days it will crank until the battery dies. If it is cold and within one day it will eventually catch and rough start.
I see a lot of people mentioning hg - dumb question but what is hg?
The most likely culprits now I am thinking are the FICM, which I do not believe they checked. If it isnt that I am thinking injectors. I have jump started my truck so many times it fills the screen when they scan it. It seems to be getting a lot of draw when the key is out to wear down the batteries. When it is warm it starts ok. -20 and it shudders and shakes until it idles normally. The cold weather definately causes it to crank for an unhealthy amount of time. I am very close to being out of warranty (147,000km) and I am tired of taking it in and having it come back in the same poor condition. I love the power, but these other issues make me reconsider what brand I will buy next.
As for the bearings, after set #3, the Ford dealer told me that there is a gap in the backing plates on the front that lets in water and allows the bearings to rust out. Their fix was silicone....
ryanv75 is offline
Old 03-22-2009, 02:09 PM   #2 (permalink)
i would find a new dealer. you probly have a leak in the high pressure oil system or like you said the ficm is bad, but the ficm will almost always throw a code, the need to monitor icp and ficm voltages while cranking for the long time to see whats not there.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 03-22-2009, 05:53 PM   #3 (permalink)
ttmech's Avatar
My Photos: (6)
Second that, find a new dealer.
'04 6.0 F-350 Red, Lariat, CC SB 4x4,power roof & rear slider,K&N ,285-75-16 BFG muds on polished EX wheels, 08 alum. diff cover, SnoPatrol package
ttmech is offline
