#6 not firing - Diesel Forum - TheDieselStop.com
Old 11-10-2012, 06:53 PM   #1 (permalink)
fordnatic68's Avatar
#6 not firing
Hey gang long time no post. Got an issue with #6 not firing. It started while driving a 400km trip I noticed it right away. Tried resettig pcm by batt disconnect, i disconnected injector while running no change. I reinstalled a new injector no change. Did a leakdown test air out the intake side of turbo tells me stuck/bent valve. Pulled valve cover one rocker was extremely tight no play at all like the rest of them.
Im just looking for some insight before I pull the heads and dig deeper. I did overheat last summer while pulling some mountain roads when fan clutch failed. It hit 260+ degrees. No coolant in oil and no oil in coolant. Im suspecting a ring or something. any advice im all ears guys thanks;]
03 F350 6.0 XLT Lariat Born 12/21/02 Crew cab short box loaded to the nuts
Autometer Guages - Pyro, Boost, Tranny, Oil Temp, Oil pressure,F & R Diff Temp,Voltage, Fuel & HPOP
Custom dash mods to clear up clutter ontop and eliminate blind spot at A pillar
Edge juice w/ attitude ( unlocked)
Banks Intercooler, Hi ram intake n tubes
Twin Optima yellow tops
BD 5" exhaust
Snow Performance Water/Methanol injection w 7 gallon tank (water only)
EGR Delete Kit
Silverline twin 8" slash cut stacks
New stock Ford Hpop
New stock Ford oil cooler (waiting for BD's version of remote cooler filter kit)
Garrett Powermax GT3788VA Turbo
Airaid cold air intake
Zoodad mod
10.5 " Procomp lift (really 8.5 w some mods)
42" good year wranglers w Kevlar sidewalls
5" Bushwacker cut out Flares
Goodhood Dual ram air fiberglass hood from US body
90 F250 Extended cab long box 460 auto
57 Mercury stepside
fordnatic68 is offline   Reply With Quote
Old 11-10-2012, 10:47 PM   #2 (permalink)
Sounds like you have a lifter pumped all the way out and stuck keeping an intake valve from seating closed. Probably #6 Since it is a valve problem switching the injectors would make no difference.
dannyboy950 is offline   Reply With Quote
Old 11-10-2012, 11:23 PM   #3 (permalink)
dcovaleski's Avatar
A couple things don't make sense though. First, what rocker was tight? And what position was the motor in? If it was on the intake or exhaust stroke on that particular piston, then one or the other rocker would definitely be tight. Second, why would you suspect a ring? Rings hold compression in a cylinder, or oil from getting into a cylinder from the wall. Bad rings, oil or compression, would not shoot air out of an intake valve.
Sent from my iPhone using Autoguide.com App
2005 F-350 cc, 6sp, 4" turbo back MBRP, 03 turbo, ARP studs, Sinister EGR delete, Southbend clutch, SCT with custom tunes and really bald tires
1996 F-350 Reg cab psd auto 187k so far so good
dcovaleski is offline   Reply With Quote
Old 11-11-2012, 12:13 AM   #4 (permalink)
I suspected a ring due to overheating and possibly making the rings brittle. All the rockers seemed fine but one, it was unmoveable. All the others had some sie to side play. I have to do some more diagnostics. Ive gone through a nasty divorce this year n my heads really not fully in the diagnostics game. Im thinking leakdown test again and go from there.
BD 5" exhaust
EGR Delete Kit
New stock Ford Hpop
Zoodad mod
57 Mercury stepside
