Old 07-18-2009, 11:28 AM   #1 (permalink)
imsolidstate's Avatar
Abnormal tire wear
Hey, my tires are getting pretty worn, so I've been looking at replacing them. The last time I inspected them, they weren't wearing properly and I haven't had a chance to put it up on jacks and check it out so I thought I would ask if anybody has ideas about what might be wrong. I want to fix it before I replace the tires.
The drivers side front tire inside shoulder is worn off and the passengers side front tire outside shoulder is worn off. When I'm going over hard bumps there is sometimes a wierd clunking noise coming from the front wheel well area. I haven't messed with any of the suspension stuff since I have owned the truck except for putting pro-comp shocks on about a year or two ago.
The other thing (don't think it's related but not sure) is when going around a corner at low speed, the front end feels like it's surging a little, similar to when you're in four wheel but not as bad. Are the hubs not releasing the front shatfts or something?
Thanks for the help.
2004 (2003 motor) F-350 CC LB King Ranch DRW.
imsolidstate is offline
Old 07-22-2009, 01:51 PM   #2 (permalink)
Anybody?
Old 07-22-2009, 03:32 PM   #3 (permalink)
Same think happened to me on the drivers side on my older 99.5 7.3 and what it came down to was the ball joint was shot. thats the clunking sound you are hearing. Tire sits at an angle and that causes the wear on the tire.
boulder is offline
Old 07-22-2009, 04:14 PM   #4 (permalink)
Thanks. It will save me some trouble now if I go get the ball joints before I tear into it. Will it need an alignment or any other adjustment after being replaced?
