? About EGR delete ? - Diesel Forum - TheDieselStop.com
 10Likes
post #1 of 32 (permalink) Old 02-08-2017, 01:41 PM Thread Starter
Justus's Avatar
Question ? About EGR delete ?
So I "deleted" my EGR via my SCT X4, but when I removed the physical EGR valve and installed the block off plate and started the truck it ran rough, and was blowing smoke like crazy. Anyone have any input on what is going on. One thing of note is that when I removed the EGR it looked like there was some gunk in the intake, do you guys think this is what was causing this?
At the time, I just put the EGR back in and everything went back to normal.
So should I put the block off plate back on and just let the truck run out all the crap and hope it gets it all out of it's system, or are there any other suggestions?
I can just leave the EGR physically in place it is not doing any harm.
2006 Ford F-350 6.0LPowerstroke
Tan, Lariat, CCLB, 4X4, CB, LineX, Bed box, 5thWheel, tow pack
MODS
BPD FICM PS, SCT X4 w/EGT probe, PHP FICM tuner, straight piped, Blue spring, coolant filtration, CAT-1/ELC,- EGR valve,
leveling kit, 35" Toyo Open Country MTs, STC upgrade, Mean Green alternator, dual Optima's, Stant Degas cap, Archoil 9100/6200
FUTUREPLANS
New oil cooler/EGR cooler delete, STUDS, diff covers, ARBs, bumpers
Justus is offline
post #2 of 32 (permalink) Old 02-09-2017, 09:32 AM
fordsforever73's Avatar
My Photos: (24)
Feedback Score: 2 reviews
Is the smoke white? It sounds like you didn't delete the egr cooler itself. If you're burning white smoke, it usually means the cooler is leaking.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. FICM by Ed with Atlas 40 tune, DC Power 185 amp alternator, MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. +More.
fordsforever73 is offline
post #3 of 32 (permalink) Old 02-09-2017, 09:52 AM Thread Starter
Justus's Avatar
Yes the smoke is white. But with the EGR valve turned off by the tuner but still physically in place the truck runs 100% fine. This only happened when I pulled the EGR valve out and put on the block off plate, that being the only change that caused the symptoms. It just seems weird, theoretically I did not change anything, the hole was plugged either way, with the EGR, or with the block off. It just seems like there would not be any physical difference between the two.
BTW, thanks for the response and help.
MODS
FUTUREPLANS
Justus is offline
post #4 of 32 (permalink) Old 02-09-2017, 04:17 PM
You can't just remove the EGR valve to do a delete. You have to physically remove or block off the cooler. If you don't you are just sucking in raw exhaust.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #5 of 32 (permalink) Old 02-09-2017, 04:24 PM Thread Starter
Justus's Avatar
Why can't you remove the EGR valve and put a block off plate if it is already deleted electrically via the tuner? What does the EGR cooler have to do with the EGR valve?
MODS
FUTUREPLANS
Justus is offline
post #6 of 32 (permalink) Old 02-09-2017, 09:00 PM
Just putting a plug in where the EGR valve is doesn't necessarily keep the EGR cooler from failing and dumping coolant into the exhaust. The 05 and up EGR coolers weren't all that reliable and one problem was handling the thermal stresses.
Mark
bismic is offline
post #7 of 32 (permalink) Old 02-10-2017, 07:32 AM Thread Starter
Justus's Avatar
Agreed, I am going to do the EGR cooler delete, I just have not gotten to it yet. So for right now I am just trying to finish up the EGR valve delete part. Anyone have any more information on this?
MODS
FUTUREPLANS
Justus is offline
post #8 of 32 (permalink) Old 02-12-2017, 11:00 PM
I'd say keep the valve in place until you do the EGR Cooler Delete
2007 F350 CCLB Lariat 4x4. EGR delete, 4" turbo back straight pipe 5'' tip, coolant filter/CAT ELC, blue spring mod, DC Power 185 AMP Alternator,HFCM plug Upgrade, Everything else STOCK. 173k- Feb 2017
ByronF350 is offline
post #9 of 32 (permalink) Old 02-13-2017, 09:17 PM
EGR Cooler vs EGR Valve
The EGR Valve physically controls the flow of exhaust that comes through the exhaust flow "center" of the EGR Cooler assembly. The cooler has coolant that flows around the outside of the "center" and cools the exhaust gasses that are flowing through the center of the cooler. If you take out the valve, it cannot shut off the flow of exhaust gasses (that flow through the cooler) into the intake. A blocking plate just closes up the hole that the EGR valve sits in. It does not block the passage that the exhaust gas flows through (the purpose of the EGR valve). Electrically deleting the valve only fixes the functioning aspects and feedback loops associated with the valve performance, it does not block off the exhaust gases from going through your intake (an EGR Cooler Delete does that). The length of this answer is probably why nobody answered your specific question. I hope it helps.
iHenry and Justus like this.
2004 F-250 FX4 Lariat SWB SRW 6.0L Torqshift, Late Engine Build 11/21/04, Dual Alternators,
Extended Cab, Med Wedgewood Blue, Tan Leather Interior, Autopage RS Alarm, Blue Spring, Dieselsite Coolant filter, ARP Studs, Ford Reman Heads (added Exhaust Valve Seats), Updated HPOP, MBRP HD Y-Pipe, RCD EGR Delete, Updated Turbo Oil Tubes. FICMRepair with Econo-tune (wish I'd gotten Atlas 40). Working out BP Perf CCV Kit Install..
Still makes me grin "almost" every time I get near it!
TurboThrill is offline
post #10 of 32 (permalink) Old 02-14-2017, 07:08 AM Thread Starter
Justus's Avatar
Thumbs up
Awesome response! Thank you very much for taking the time to give a full and complete answer. That is what I did not understand, now it makes sense. Thank you very much for your assistance TurboThrill.
MODS
FUTUREPLANS
Justus is offline
post #11 of 32 (permalink) Old 02-14-2017, 09:23 AM
If I am understanding the use of the term block-off plate now, you are saying just a cover plate (which isn't any kind of block off at all)? I haven't seen one or heard of people using only them until now. As turbothrill posted so well, this would allow full EGR recycle all of the time, which isn't good!
However, there are plugs that look like an EGR valve that are simply plugs, no moving parts. They do prevent exhaust gas from flowing to the intake, but they are downstream of the EGR cooler so they allow the EGR cooler to heat up (fill with exhaust at full exhaust pressure). So they still see thermal cycling - which can cause failure. If the cooler fails, even with a plug, this can allow coolant loss (and also exhaust gasses into the coolant), since coolant is still flowing around the internal elements (plates or tubes) of the EGR cooler. An EGR valve that closes and stays closed should also prevent exhaust flow to the intake but they don't always stay closed.
Name:	Air Flow - 6.0L.jpg
Justus likes this.
Mark
bismic is offline
post #12 of 32 (permalink) Old 02-14-2017, 09:40 AM Thread Starter
Justus's Avatar
So the best thing is to leave the EGR valve in place even though it is deleted electronically?
MODS
FUTUREPLANS
Justus is offline
post #13 of 32 (permalink) Old 02-14-2017, 09:47 AM
IMO yes (I agree w/ ByronF350).
So let me verify something. This block off plate that you describe is simply a cover plate that fits over the hole that the EGR valve fits down into? If so, where did you get that plate?
Mark
bismic is offline
post #14 of 32 (permalink) Old 02-14-2017, 10:24 AM Thread Starter
Justus's Avatar
Yes, it just covers the hole the EGR valve sits in. I do not remember what the brand was, why?
MODS
FUTUREPLANS
Justus is offline
post #15 of 32 (permalink) Old 02-14-2017, 10:41 AM
I haven't seen anyone sell just a cover plate before since it allows for uncontrolled EGR recirculation all the time. Engines don't run well that way as you discovered!
I would highly question any shop that just sells a simple cover plate for the 6.0L.
It must have a plug for the passageways.
Justus likes this.
Mark
bismic is offline
