so about 2 weeks ago i fired up my truck and went to go hook up the trailer, i noticed when i started moving that the ABS light came on, no big deal .then i noticed that the speedo wasnt moving then all of a sudden it dropped down below 0.
did some reading to come find out that its most likely the sensor in the rear diff, tryed to test it but it seemed dead so i just replaced it with a new one. after a couple miles everything fixed itself, speedo came back and abs light went off....
so today i fire up the truck, go to hook up the trailer(maybe its cursed lol) and the same BS happens, the abs light comes on, hit the road and the speedo needle goes below 0
is the same sensor dead again? what would cause this, anything wiring related i can check out? maybe the diffs tore up inside and toasting sensors? cheap/junky sensor just S#$% the bed maybe?
maybe its the sensor in the tranny this time? i get a p0500 code this time,didnt even think to check for coded with the edge last time.
any help would be appreciated!
gonna wait till tomorow to crawl underneath there and see if the sensor is dead again
