AC Compressor Clutch - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 04-06-2011, 10:30 AM Thread Starter
I have a 2004 F250 6.0 with a bad AC compressor clutch. I plan to have it repaired by someone else because of lack of time. Anyone have a rough idea of how much this costs?
LDSDJohn is offline
post #2 of 5 (permalink) Old 04-06-2011, 02:20 PM
Mark Kovalsky's Avatar
My Photos: (6)
I've had really bad results trying to replace just the clutch. The clutch failed for a reason, and that reason usually is that the compressor is dying. I recommend biting the bullet now and replacing the compressor and the clutch. Otherwise I suspect you'll pay to do it again.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is online now
post #3 of 5 (permalink) Old 04-06-2011, 10:11 PM Thread Starter
Thats a good point. Thanks. How much did it cost you? You do it your self?
LDSDJohn is offline
post #4 of 5 (permalink) Old 04-06-2011, 10:14 PM
Check on line with major auto parts for cost idea
02 PSD Lariat CC DRW, 4X2, A/T, 4:10, Big Tex grill guard ,115 gal in bed fuel tank (switch on the go) ,5er notched in bed tool box, Reese 5er/gooseneck/bumper hitch, 20K fan powered under cab tranny cooler, AFE intake, Super chip, TC lock up, Gear vendors exhaust brake, 4 inch turbo back exhaust, oil/water/egt/boost/tranny/diff guages, CB radio, Back up camera, Air bags (inside cab control), Mag-hytek tranny/diff pans,, Ram tough computer stand, FS2500 Aux Oil filter, Turbo life saver, Turbo Master wastegate actuator
Fordpowerstroke350 is offline
post #5 of 5 (permalink) Old 04-07-2011, 10:36 AM
My Photos: (6)
I put a clutch on myself about 10 years ago. It was $100-$150 if I remember correctly. Three weeks later I spent $1300 to replace the compressor and much of the rest of the system when the compressor was trashed and spread junk throughout the system.
I know of many others that have replaced clutches and then replaced the clutch and compressor when the compressor failed soon after.
Mark
Former
