Accelerating differences - Diesel Forum - TheDieselStop.com
Old 05-04-2005, 11:50 PM   #1 (permalink)
When at 65 MPH or so my truck doesn't seem to move up to 90 or so with a WOT nearly as fast as it does if you are starting from a stand still or a slower speed and then go WOT. What is the difference with the tranny and TC? Anyone elses seem to do better from a slower speed then it does from a faster speed??
TRADED: 2004 F250, XLT, CC, SB, FX4, 4x4, 6.0 PSD, Torque Shift, Arizona Beige
May 04 Build Date.
06 F250, XLT, FX4, 6.0, Torque Shift, Dark Stone, Rancho 4" Lift, Banks Turbo Back Monster Exhaust, Intake Elbow, Auto Meter Pillar Gauges, Pro Comp 325/60-18 on Weld 18x10 Cheyenne wheels.
BoostMe is offline
Old 05-05-2005, 12:12 AM   #2 (permalink)
Re: Accelerating differences
All depends on the speed and what gear you are in. Is it droping a gear when you hit it? I don't recall speeds and gears but sometimes I hit it and it only drops 1 gear, sometimes it drops 2.
What your gear ratio? 3.73s? 4.10s?
2004 F-250 Oxford White/Silver XLT FX4 4x4 SC/LB
6.0 Powerstroke 3.73s
Scotto2323 is offline
Old 05-05-2005, 01:18 AM   #3 (permalink)
gear ratio.
Wind resistance.
The engine puts out the same power at 0 as it does at 90.
-T
2008 F550 6.4 w/ pickup bed
kehale is offline
Old 05-05-2005, 11:03 AM   #4 (permalink)
You have more momentum when climing up to and past 65 mph on your way to 90 mph than you do when your cruising at 65 mph and then floor it to get to 90 mph. I think that makes sense. When you coming from a stand still and you hit 65 mph you have alot of momentum built up so you can easily keep on going up to 90 mph.
2005 F-350 SRW, Lariat, crew cab, 6.75 ft bed, 4x4, auto, True Blue, 70k miles, stock.
Sold: 2004 F-350 Reg-Cab XLT, 4X4, SRW, 6.0 PSD, 6 speed, manual transfer case, Dark Shadow Grey, 285/75R16 Cepeck FC-II's on 16X8 Centerline wheels. built 3/23/04, 125K miles.
Canyonero02 is offline
Old 05-05-2005, 11:22 AM   #5 (permalink)
there's also that 3 or 4 seconds of turbo lag....
kehale is offline
Old 05-05-2005, 01:27 PM   #6 (permalink)
ctg
This doesn't make physical sense. Momentum will not help you accelerate. The difference should be entirely due to engine revs and turbo already being spooled up accelerating "through" 65 rather than from a 65 mph roll.
ctg is offline
