Advice on blown motor, 6.0 '04 - Page 2 - Diesel Forum - TheDieselStop.com
Old 03-09-2005, 04:11 PM   #16 (permalink)
Re: I have never owned Ford, but I would be pretty upset if they refused to
stop playing around and drop a cummins in it. You'll just grenade another 6.0.
2000 Black Excursion,PFC 2 piece rotors,Tipton tuned,BDP stage 2 singles, BDP H2E, AFE stage 2, Spearco 7.3, ITP Reg. return fuel system, Evans, BTS, 186,000 miles....And still goin' strong! Thanks Beansdieselperformance.com and Puredieselpower.com for all your help
BBBxcursion is offline
Old 03-09-2005, 05:44 PM   #17 (permalink)
My Photos: (27)
Sure is strange, we run the edge with no problems! I think it has more to do with folks running these things like hotrod gassers! If you don't let the engine completely warm up and go mash on the throttle like a gasser bad things will happen!
IRAQI WAR VET AND PROUD OF IT!
2008 F250 FX4 6.4
SUPERF350 2006 F350
POWDER COATED CAC TUBES
PROJECT TRUCK 85 F250 4X4 6.9 6.0 IN IRAQ
superf350 is offline
Old 03-09-2005, 07:41 PM   #18 (permalink)
ta152h0's Avatar
I am sure there is much more to this story than originally posted. I'd like to hear from the friend himself
Wolf
Kentucky built 2004 Silver F-250 XL Reg Cab PSD, 4X2, bench cloth seat,air conditioning, 6 spd Manual, 3.73 LS,Line-X , FORD receiver, Prodigy brake controller,towing option,( put together on Monday, March 29, del April 9 2004) 62000 miles
ta152h0 is offline
Old 03-09-2005, 08:47 PM   #19 (permalink)
He has owned nothing but Ford diesels for 15 years, so he is well-versed on the intricacies of the diesel motor as well as turbo maintainance. We have 4 Ford 7.3 diesel work trucks and 4 Cummins Dodges and have had no real problems with anything except trannies before. I advised him to appeal it to the regional office of Ford and if that doesn't work, you can request a hearing with a state mediatior.
Are there any lawyers that are just plain out-to-get Ford that he could contact?
InThEtHiCkEt is offline
Old 03-09-2005, 09:10 PM   #20 (permalink)
rock_doctor's Avatar
Sounds like a plan. Do a google search about lawsuits against fd and see if there are any that originated in your state. There is a long distance between here and there. The dealer will pull the engine and partially disassemble it, and then an engineer will come out to look it over. Even with the negative nature of my posts, he may determine that a head or block cracked or something not fuel related. Wait to see what they say then go from there. This thread has given you a taste of what your buddy may have to go through if things go very wrong. It just may work out and the failure had to do with a poor casting or something like that, it has happened before. I remember a guy on the 7.3 forum blew an engine and it turned out the engine sucked in a freeze plug mounted in the head. They fought him at first then gave in and replaced the engine.
good luck,
mark
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 03-09-2005, 10:00 PM   #21 (permalink)
Re: Advice on blown motor, 6.0 '04
They brought in a Ford guy and when he saw the plugged bung for the EGT sensor, he voided the warranty on the motor and refused to look further to see what failed.
Okay, you are telling me they voided the whole engine warranty just because they saw where an EGT probe had been mounted? They didn't even say there was a box on there ? Holy cow, Ford is getting very trigger happen on denying these warranties.
However, I have to agree with others. Fords fault or his fault is now irrelevant. He shouldered all fault once he put that box on the engine. Now the onus is on him to prove it didn't cause the engine to fail.
The argument that the engine seiezed up when Ford service had it won't hold water either. That engine was already messed up by the time they got it. That's like sayin that you may have shot a guy, but since he died in the ambulance on the way to the hospital that the county is responsible for his murder.
David
_________________________________________
2006 Dodge CTD 325/610 SLT 4x4 Mega Cab
ARE LSII Bed Lid
djp9747 is offline
Old 03-09-2005, 10:15 PM   #22 (permalink)
Did He Say That He Had A Box On It. I Took Mine In With A EGT Bung For The Sensor & Ford Did Not Say One Word About When My Motor When Out But The Valve Train Came A Part And Took A Cylinder Out. I Would Look Futher Into This.
Good Luck With It
2004 F250 6.0 Diesel CrewCab 4x4 ShortBed Silver, R.B.P Exhaust, K&N Filter. New Motor At 4000 Miles New Trans at 12000 Miles
Love The Truck Still With The Problems.
silverponyracing is offline
Old 03-10-2005, 12:52 AM   #23 (permalink)
If you heat up your engine with a box, there are tell-tale signs (and not just in the computer). When they pull the head, it's easy to see.
Also, the Edge thermocouple says "Edge" on it.
You wanna play, you gotta pay. 325 horse is good enough for me. (for now)
-T
2008 F550 6.4 w/ pickup bed
kehale is offline
