Advice on Frequency of Driving - Diesel Forum - TheDieselStop.com
Old 12-04-2008, 10:35 PM   #1 (permalink)
Hi Guys, I have a couple of questions for you.
I own a 2004 F450 used mainly for towing my 5th wheel. It currently has 39K on it. I normally drive it once a week to keep the turbo oiled. Is that enough to keep the engine in good shape. The turbo and transmission were replaced under warranty about two years ago.
The only maintenance I've done so far are oil and fuel filters. The tranny fluid was replaced when the new transmission was installed. Is there other important items I should do with a low mileage 4 year old truck?
Thanks for your help.
MikeinAsheville is offline
Old 12-04-2008, 11:41 PM   #2 (permalink)
replaced and you only have 39 k miles?
grrr make the horror stories stop. luck you have a warranty!
$lick is offline
Old 12-05-2008, 04:40 PM   #3 (permalink)
MikeL46's Avatar
My Photos: (14)
As long as you are driving it long enough to fully warm the engine (20+miles) it should be OK. Basically, that is all that I do - oil and filter changes (engine -7500 miles, Trans - 30K miles), fuel filters (15K miles and lube (every oil change).
And don't run it hard (pull up a big hill) and shut it off . Let it run a few minutes to cool the turbo before you turn it off.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 12-06-2008, 11:40 AM   #4 (permalink)
Mike
Good advice! I'd get it out on a highway for about half an hour after the temp gauge moves.
You might want to look into a battery tender as well. If you don't get your rpms up into the 1.5 to 2 k range for better than 20 mins or so, the alternator doesn't have a chance to refresh the charge in the batteries.
OMC
OMCUSNR is offline
