AGAIN!! Bent Push Rods #1 & 3 - Diesel Forum - TheDieselStop.com
post #1 of 22 (permalink) Old 05-28-2007, 10:22 PM Thread Starter
Here we go again. The truck left me and the family stranded in the middle of nowhere with the exact same indicators as last time, loss of power, major miss, loud popping from the intake. I have put under 1000 miles,(one month) on the truck since I got it out of the dealership for bent push rods in cylinders 1 & 3. Prior to this time the same problem at 211 miles, then at 17,500 then at 24,800 and again now. Each time the rods and valve train were replaced. This last time the heads were also replaced. I have spoken to Ford and they think the same repair should be done, AGAIN. See my previos posts under bent rods, or, in shop for 39 days. The truck just turned 26,000 miles. Is there any hope? Last time the Ford rep started talking buy back, and sent me a months payment until the repairs were completed. What do you think I need to do? Thanx in advance.. I will keep this updated.
2004 F-350 Crew Cab, Auto, 6.0 XLT Lariat, Leveling Kit, Rhino Spray in liner, Towing 33' Toy Hauler
Lockup13 is offline
post #2 of 22 (permalink) Old 05-28-2007, 11:03 PM
Re: AGAIN!! Bent Push Rods #1 & 3
Buy back if you can. If the same problem is happening like that i would have to think it would be the dealership not knowing what they are doing
2012 F-350 CC SB SRW King Ranch
uga33 is offline
post #3 of 22 (permalink) Old 05-28-2007, 11:05 PM
darsey715's Avatar
I'd try and get ford to send an engineer specifically for my truck. or discount an 07' big time.
2003 6.0 f250
darsey715 is offline
post #4 of 22 (permalink) Old 05-28-2007, 11:09 PM
ta152h0's Avatar
I remember there is a keeper over the lifters that was not installed on some engines.I have to go find it in my manual and get back to you.
Wolf
Kentucky built 2004 Silver F-250 XL Reg Cab PSD, 4X2, bench cloth seat,air conditioning, 6 spd Manual, 3.73 LS,Line-X , FORD receiver, Prodigy brake controller,towing option,( put together on Monday, March 29, del April 9 2004) 62000 miles
ta152h0 is offline
post #5 of 22 (permalink) Old 05-29-2007, 12:14 AM Thread Starter
The repairs have been done by 3 (three) different dealers in 3 different states. HELP!!!
Lockup13 is offline
post #6 of 22 (permalink) Old 05-29-2007, 02:48 AM
Banned
Does this truck have any equipment we aren't being told about? This is a question that needs to be asked.....
Repeat failures involving the same cylinders should have alarm bells going in some techs mind.... (knowing vehicle history can be a wonderful thing).
Some considerations.... all of your problems appear to involve bank 1 (the right hand or passengers side). From memory, the failures appear to involve the front two cylinders on that side. Sometimes, the smallest clues can lead to the biggest gains...
GrampyJim is offline
post #7 of 22 (permalink) Old 05-29-2007, 03:16 AM Thread Starter
None that I know of. No chips or upgrades were added. Stock exhaust, stock everything. My signature is all I have. Unless the dealer I purchased it from did not disclose something. Thanx...Please keep thinking!!!!
Lockup13 is offline
post #8 of 22 (permalink) Old 05-29-2007, 09:29 AM
Is it always the exhaust pushrods?
Does this truck have phenomenal deceleration in tow/haul mode?
I'm thinking out loud but if the vanes had too much travel and were really restricting exhaust the possibility exists that the pressures might be holding valves open and bends the p'rods. I know it is a stretch but in my days of dealing broken autos professionally I have seen some weird stuff that defies normal logic. I would think the pressure build up would not effect only those two cylinders but reflected gas pressure waves don't follow logic.
I know this is just a notch or two up from Demonic possession as a cause but the things already replaced rule out a whole lot of other things. The way I understand the VN turbo, a mis-indexed assembly might increase the travel of vanes one way or the other........
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 136K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 147K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
2002 F350 CC DRW flatbed (originally pickup bedded) rebuilt & upgraded 4R100
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 164K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 241K (no engine repairs)
2007 BMW 550i 6MT 146K, Stuff breaking all the time that would last twice as long on a Kia or Hyundai, sad. Drives great though.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #9 of 22 (permalink) Old 05-29-2007, 09:40 AM Thread Starter
I believe the bent rods were exhaust. but don't hold me to it. The repair paperwork is not that specific. It has had a turbo replacement 10,000 miles ago.
Lockup13 is offline
post #10 of 22 (permalink) Old 05-29-2007, 09:44 AM
My Photos: (38)
Cylinders 1 and 3 are the closest ones to the EGR system. You may have a fault with that...
It is possible that a small amount of coolant from an EGR cooler leak could rust the intake valve stems on 1 and 3, and bend the pushrods when the valves won't open... But that's a long shot...
What sig?
GregH is offline
post #11 of 22 (permalink) Old 05-29-2007, 09:58 AM Thread Starter
With only 1000 miles after new rods were put in?
Lockup13 is offline
post #12 of 22 (permalink) Old 05-29-2007, 10:55 AM
My Photos: (38)
Well, if the root cause is a leaking EGR cooler, for instance, that is causing rust buildup on #1 and #3 intake valve stems, then replacing the pushrods for those cylinders won't fix anything... The new pushrods will bend just as fast as the old ones did...
What sig?
GregH is offline
post #13 of 22 (permalink) Old 05-29-2007, 08:03 PM Thread Starter
The truck is driven daily. Is that still a possibility?
Lockup13 is offline
post #14 of 22 (permalink) Old 05-30-2007, 12:15 AM
ta152h0's Avatar
here is what possibly could be your trouble.
2004 FORD manual for the F250, 350, 450,550 section 303-01c-167
30. Caution-to prevent engine damage, keep the cam followers in the order they were removed. Install the cam followers back in their original positions
NOTE- only the front guides use bolts.
that last sentence tells me it is possible no bolt was installed.
Wolf
ta152h0 is offline
post #15 of 22 (permalink) Old 05-30-2007, 01:00 AM Thread Starter
At three different dealers? Three times? Could they really be that poor of mechanics? Do I let them try again or pursue a buy back?
Lockup13 is offline
