Old 07-17-2009, 05:57 PM   #16 (permalink)
waylntat2's Avatar
Smile
I have a 2004 54000 miles Bought it used at 18000 miles in 06 Bought a new mc air filter still have not put it in the minder has not moved, lot of highway, little dusty roads,I have a minder on a trackhoe it, works guess the trucks will also
2004 F250 SD XLT Fx4 Grey mett. Soft tanto cover, 6.0 PSD Towhaul/Water coolant Filter/custom pinstipes By twisted Image,Highvolts/42.000 miles 2/08
waylntat2 is offline
Old 07-17-2009, 08:38 PM   #17 (permalink)
HeavyAssault's Avatar
My Photos: (6)
I usually follow the Owner's manual for my change interval. I have only had one instance where the filter minder actually moved a little bit. Those Donaldson filters are top notch!!
If you want to make your filter changes a tad easier just mod the snorkel and dp the ZOODAD mod. Plenty of fresh air and filter are swapped in under 2 mins. I have had this on my '06 for over 100K so it works and works GREAT.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 07-18-2009, 04:58 PM   #18 (permalink)
Mostly solid advice here. The only thing I would add is that if you do the "zoodad mod", (which is simply cutting a hole in your inner grille to allow more cold air flow to AF), you also make a small block-off plate w/ thin plywood to drop in front of hole when driving in significant rain.
I have the zoodad hole and recently drove through a massive thunderstorm in SD for an hour or two @ 70+ mph. My AF got absolutely soaked, (at least the front of it), to the point where it moved my filter minder. This is with a brand new OE filter.
I'd stick w/ an OEM Ford filter, as others have said they can last forever in non-dusty conditions. They are ~$100 list but I found mine online for under $50 including shipping. Some of the knock-off filters are OK but supposedly not as good as the blue ones. Considering the role of an AF on our engines and how infrequently they need changing, it's a bad place to scrimp IMO.
2005 F-250 4x4 SC SB 6.0 stock
Minnesota is offline
Old 07-18-2009, 05:55 PM   #19 (permalink)
And get the filter w/ the blue synthetic media - it is more water resistant.
Mark
'06 F250, CC SB ESOF FX4 Lariat 3.73LS, 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto valve; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & Britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
bismic is offline
Old 07-18-2009, 06:55 PM   #20 (permalink)
As a side note, If you have a mod unfriendly dealer and have to take the truck in for turbo or certain engine warranty problems, you could have your 5 yr/ 100, 000 mile engine warranty voided.
69cj is offline
Old 07-19-2009, 01:07 AM   #21 (permalink)
it's real easy to change if you disconect at the turbo , then everythibg pulls out nicely. i change mind at 30k intervals, i've never had the filter minder show anything but good. , but mine melts when the gasses escape from the degass bottle, so it's new every month or so.
2004/04 engine-psd-cc-4x4-auto-lb-engine blown-ford putting in a new one-gave back to ford engine still puking antifreeze-vin-1ftsw31p84eb24255-watch out for this in canada. 06 started puking , ford won't fix untill it completley goes. so i park it and i buy a dodge. had enough of the crappy fords and them refusing to fix them
2004 cardinal 35ts
new 06 PSD same as above only it's a Lariat, this one started puking as well.
bigwhite1 is offline
Old 07-24-2009, 09:52 PM   #22 (permalink)
DenverGeitgey's Avatar
Air filter
I took the whole snorkle off of my air filter and run the open element. It works real well has given me a tad more milage ( 20.4 mph on the eway ) and 15.0 with my 28 ft. fifth wheel camper.17-18 around town. Other mods include straight stacks, diablo predator, egr unplug. No leaks .... Plenty of power...... and it will smoke all six.....
DenverGeitgey is offline
