I replaced my air filter minder today burt could not get the air flow indicator light to reset/go out. What's the trick on getting the light to reset???
How hard do you press the reset button? Do you press and hold it for a second or two?
My old minder was cracked in half (I assume from the AZ heat) so I'd be surprised if there was a wiring problem. When the old minder cracked in half the air flow indicator light tripped and has been on since then.
My minder broke a few months ago (MY FAULT) the indicator lite stayed on . As soon as I replaced with a new one the light went off. So as bismc stated you might have a short.
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
