Air filter restriction gauge - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 12-11-2005, 12:21 AM Thread Starter
Does anyone know how to read the air filter restriction gauge? (It looks like a little plunger located on the stock airbox) It's supposed to read the air restriction and let you know when to change the air filter. The manual says to check it at 7500 miles, and replace the air filter if needed. Also, i need a general idea of when are you all changing your air filters.
After reading all the posts, I have decided to leave the intake stock. The magority of members have said that the stock Donaldson flows well and filters the best. It seems the general consensus is that the minor improvement in flow of aftermarket intakes does not make a significant difference in throttle response. If anyone has a different opinion or experience please share it with me. I have learned a lot from the members on this site.
Thanks in advance
06 PSD, True Blue, SCMT running econo tune, MBRP stainless cat back system.
06 PSD, True Blue, MBRT Cat Back, 35" M/T ATZ, 4" Pro Comp lift
mullens41 is offline
post #2 of 7 (permalink) Old 12-11-2005, 06:35 AM
Re: Air filter restriction gauge
After owning 4 different 6.0's I have never seen them move even slightly. I think the filter has to be real dirty and blocked for it to move. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Too much junk/toys to mention, ever changing due to too getting bored too quickly. I need a 10 step program!
Want to call? I'm in the book. Want to argue....First explain the square root of negative one....lol
roofeditor is offline
post #3 of 7 (permalink) Old 12-11-2005, 11:29 AM
ritschner's Avatar
Send a message via AIM to ritschner
The yellow band will move toward the air filter under heavier loads. The dirtier the filter the further it will move. It will stay at the furtherest point until reset by pushing in the yellow button on the end. The factory filter should last at least 30k miles under highway conditions. If you want to check the filter minder, you can unplug it, then remove by slowly pulling and twisting it out of the grommet. Then suck on the end, you should be able to draw the indicator all the way to the end fairly easily. Just make sure you reset and plug it back in when you reinstall it.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Bilsteins, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB, Accufab elbow, Edge Attitude CS, Blue Spring Mod, DCPower 185a alternator, Rebuilt FICM, STC and Standpipe update, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
post #4 of 7 (permalink) Old 12-12-2005, 10:33 AM
Black05's Avatar
I've got 30,000 miles on my 05 (mostly highway) and the air filter restriction gauge has not yet moved. Engine performance and mpg have not decreased. I plan on changing it after 50,000 (just because)if the filter lasts that long without showing restriction or loss of engine performance.
My .02.
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
post #5 of 7 (permalink) Old 12-12-2005, 11:58 AM
We had a heavy snow storm here on Friday. On the way home from work I had my light on the dash go on telling me the filter needed replacement. I got home and the gauge on the filter was peged all the way in. I pushed it on the back to reset it. I then revved the engine and the guage did not move. I have heard on here before that sometimes in heavy rain or snow they get clogged.
2004 F-350 Lariat supercab 8ft bed
6.0 w/ Torqshift
Dark Shadow Grey w/ Black Accent
3.73 Limited slip
ESOF, Power rear sliding window, FX4 package
Tele/HTD/lighted mirrors
Pioneer AVIC-N3 navagation/ roof lights
Adjustable accel/brake pedal
Reverse sensors/ heated seats
polished cab steps
MFD 02/04
Edge Insight with turbo timer and EGT probe
Sirius Satellite Radio
XM Radio
XM Navtraffic
2004fx4 is offline
post #6 of 7 (permalink) Old 12-12-2005, 12:38 PM
ritschner's Avatar
Heavy snow can definitely clog the air filter housing. The good thing is when it melts it will run out of the drain hole and the filter housing will unclog and be back to normal. Just revving the engine does not pull anywhere near the amount of air the engine will draw at high revs and boost pressures.
post #7 of 7 (permalink) Old 12-12-2005, 03:37 PM
Black05's Avatar
True enough, I've read the same thing from others with the same experience. If I ever have the problem with snow occluding the filter in southeast Texas, the rest of the country will be in the next ice age! [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Texas Proud.
Black05 is offline
