ALL 6.0L's NEED A COOLANT FILTER!!!! - Diesel Forum - TheDieselStop.com
post #1 of 37 (permalink) Old 08-09-2009, 02:35 PM Thread Starter
dikkstarr's Avatar
After driving around with blown head gaskets for a few months back in early '05 I must have run 30 gallons of coolant though it before I got it fixed. Then Ford flushed it when they fixed it and since then, I've flushed it three more times. I thought I shouldn't need a coolant filter kit with how many times my trucks had the coolant flushed and changed, there shouldn't be anymore crap in there right?
Well last month I installed a coolant filter kit and ran the first filter for about 1500 miles before changing it. I thought I could run the first filter longer because of how many flushes I had before. I still had good coolant flow through the filter because I could see it flowing into the degas bottle, but wanted to see what was in the filter so far.
I was shocked when I cut the filter open. There was about half an inch of rusty silty mud in the bottom of the filter with a few big clods of grity sand. I wouldn't have believed it if I didn't see it. These engines have a lot of dirt it the cooling systems and flushing them won't get them clean, only a filter will!! Totally worth the money!!
If you don't have one, you need to get one trust me.
2004 F-250
dikkstarr is offline
post #2 of 37 (permalink) Old 08-09-2009, 03:57 PM
FTG-05's Avatar
My Photos: (25)
Actually, all Ford 6.0 PSD's come from the factory with a coolant filter.
Unfortunately, it's the oil cooler.
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
post #3 of 37 (permalink) Old 08-09-2009, 08:13 PM
06yz125's Avatar
Generally, what mileage do you usually start seeing or getting the symptoms of a restriction?
Also, where is the oil cooler filter located?
Thanks AGAIN
Gary
03 F250 6.0 4X4 Lariat with 66K miles
06yz125 is offline
post #4 of 37 (permalink) Old 08-09-2009, 08:29 PM
Ipolute's Avatar
its under the oil filter... you have to take off a few things to get to it... im procrastinating on putting mine in....
2005 F350 Lariat 4x4 6.0 Crew Cab
BFGoodrich Mud-Terrain KM2 35 x 12.5
Leveling kit
8k HIDs w/fog lights
Recon Side Markers(Smoked)
Recon Roof Lights(Smoked)
Harley Davidson Headlights
White L.E.D lights (Parking and Roof lights)
DieselSite Coolant Filter
3.5 Inch straight Exhuast.
Bully Dog Triple Dog w/outlook monitor
Cobra XRS R9G Radar Detector
Sinister EGR Cooler "fix"
.....At the Track.....
Ipolute is offline
post #5 of 37 (permalink) Old 08-10-2009, 12:15 PM
bobsherrie's Avatar
Thanks AGAIN
Gary
There isn't a filter in the oil cooler. I think Albin was being sarcastic when he said that the oil filter is the coolant filter as it seems to plug up due to the cr****p in the cooling system. Best plan is to buy and install a coolant filter kit. Mine is coming!
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline
post #6 of 37 (permalink) Old 08-10-2009, 01:55 PM
FTG-05's Avatar
My Photos: (25)
Correct.
Here's a pic of a plugged up oil cooler. Pretty much acts like a coolant filter when it's plugged up.
Name:	IMG_2266 (Medium).JPG
FTG-05 is offline
post #7 of 37 (permalink) Old 08-10-2009, 07:09 PM Thread Starter
dikkstarr's Avatar
Yeah the oil cooler is a coolant filter, just a very expensive one after it gets plugged!!! The add on one is better, and cheaper.
2004 F-250
post #8 of 37 (permalink) Old 08-10-2009, 07:33 PM
Just ordered the kit for my 06 F250. Its actually in the shop for the first time @ 76k miles because it was loosing coolant for the first time since brand new. How do I make sure Ford does what they are supposed to with the EGR and oil cooler?
2006 F-250 4x4 SC XL 6.0 3.73 (103k miles)
HG & ARP @ 73k Miles / new oil cooler @ tear down
EGR Fixed Permanently, 4" Turbo Back, Amsoil Bypass, Coolant Bypass, SCT econo from DP
6" Lift w/ 35" Tires on stock rims
Tweintz is offline
post #9 of 37 (permalink) Old 08-10-2009, 09:08 PM
06yz125's Avatar
So you usually start seeing restrictions at 70-80K miles?
06yz125 is offline
post #10 of 37 (permalink) Old 08-10-2009, 11:02 PM
FTG-05's Avatar
My Photos: (25)
The pic of the oil cooler that's plugged up that I showed earlier came out of an '04 PSD with 44k miles on it at the time the oil cooler was replaced.
FTG-05 is offline
post #11 of 37 (permalink) Old 08-11-2009, 12:03 PM
Strokin' 6.0's Avatar
It was the best money I ever spent on this truck. If OTR trucks have them, it's a good idea to run them on ours too.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
2012 Ford bed w/Factory Reese hitch option
4.10 TracLok
Dieselsite Coolant Filter
IH Fleetrite ELC
Blue Spring Update
43,956 miles - Replaced 6.0L
54,814 miles - Turbo
94,943 miles - Fan clutch
98,755 miles - FICM
127,057 miles - Aftermarket Alternator
154,120 miles - HPOP & Oil Cooler
168,514 miles - Radiator, water pump, t-stat & hoses
178,810 mles - #7 injector
181,807 miles - A/C Compressor
199,458 miles - Motorcraft Alternator
199,506 miles - FICM
199,521 miles - #1, #4, #8 injectors
Strokin' 6.0 is offline
post #12 of 37 (permalink) Old 08-11-2009, 08:52 PM
philhyde's Avatar
Where does one get a filter kit?
2006 F250 Crew Cab Lariat 4x4 6.0L
philhyde is offline
post #13 of 37 (permalink) Old 08-11-2009, 10:23 PM
FTG-05's Avatar
My Photos: (25)
Make your own or buy a kit. I've done both and installing the kit was far easier and not much more expensive, certainly not worth the time, IMO.
Most of the major diesel vendors have a kit. The on I like is from Dieselsite.com here: DIESELSITE&reg Products - Coolant Filtration Systems
FTG-05 is offline
post #14 of 37 (permalink) Old 08-12-2009, 02:16 AM
dwelch1's Avatar
My Photos: (5)
do you lose any coolant on the filter changes? should I pick a gallon up or just monitor the low level mark on the degaus bottle? my coolant filter kit came today.
2015 F-250 Crew Cab, Lariat, 4x4 Magnetic
13K miles so far. Retrax Pro Cover
Relaced My:
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter
dwelch1 is offline
post #15 of 37 (permalink) Old 08-12-2009, 08:31 AM
Supporting Member
scrimshaw's Avatar
I have an 07 still under warranty - does anyone know if Ford sees the installation of a filter kit as an excuse to void warranty?
2007 F350CC 6.0L,
XLT, Wedgewood Blue/Silver,
Auto, LB, F/x Camper option,
upfitters, Tow Command System
scrimshaw is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
