ALL 6.0L's NEED A COOLANT FILTER!!!! - Diesel Forum - TheDieselStop.com
Old 08-09-2009, 01:35 PM   #1 (permalink)
dikkstarr's Avatar
After driving around with blown head gaskets for a few months back in early '05 I must have run 30 gallons of coolant though it before I got it fixed. Then Ford flushed it when they fixed it and since then, I've flushed it three more times. I thought I shouldn't need a coolant filter kit with how many times my trucks had the coolant flushed and changed, there shouldn't be anymore crap in there right?
Well last month I installed a coolant filter kit and ran the first filter for about 1500 miles before changing it. I thought I could run the first filter longer because of how many flushes I had before. I still had good coolant flow through the filter because I could see it flowing into the degas bottle, but wanted to see what was in the filter so far.
I was shocked when I cut the filter open. There was about half an inch of rusty silty mud in the bottom of the filter with a few big clods of grity sand. I wouldn't have believed it if I didn't see it. These engines have a lot of dirt it the cooling systems and flushing them won't get them clean, only a filter will!! Totally worth the money!!
If you don't have one, you need to get one trust me.
2004 F-250
dikkstarr is offline   Reply With Quote Quick reply to this message
Old 08-09-2009, 02:57 PM   #2 (permalink)
FTG-05's Avatar
My Photos: (25)
Actually, all Ford 6.0 PSD's come from the factory with a coolant filter.
Unfortunately, it's the oil cooler.
'06 F-350 SRW 6.0 PSD
FTG-05 is offline   Reply With Quote Quick reply to this message
Old 08-09-2009, 07:13 PM   #3 (permalink)
06yz125's Avatar
Generally, what mileage do you usually start seeing or getting the symptoms of a restriction?
Also, where is the oil cooler filter located?
Thanks AGAIN
Gary
03 F250 6.0 4X4 Lariat with 66K miles
06yz125 is offline   Reply With Quote Quick reply to this message
Old 08-09-2009, 07:29 PM   #4 (permalink)
Ipolute's Avatar
its under the oil filter... you have to take off a few things to get to it... im procrastinating on putting mine in....
2005 F350 Lariat 4x4 6.0 Crew Cab
BFGoodrich Mud-Terrain KM2 35 x 12.5
Leveling kit
8k HIDs w/fog lights
Recon Side Markers(Smoked)
Recon Roof Lights(Smoked)
Harley Davidson Headlights
White L.E.D lights (Parking and Roof lights)
DieselSite Coolant Filter
3.5 Inch straight Exhuast.
Bully Dog Triple Dog w/outlook monitor
Cobra XRS R9G Radar Detector
Sinister EGR Cooler "fix"
.....At the Track..... http://www.youtube.com/watch?v=vMiWo6i5ZVA
Ipolute is offline   Reply With Quote Quick reply to this message
Old 08-10-2009, 11:15 AM   #5 (permalink)
bobsherrie's Avatar
Thanks AGAIN
Gary
There isn't a filter in the oil cooler. I think Albin was being sarcastic when he said that the oil filter is the coolant filter as it seems to plug up due to the cr****p in the cooling system. Best plan is to buy and install a coolant filter kit. Mine is coming!
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is online now   Reply With Quote Quick reply to this message
Old 08-10-2009, 12:55 PM   #6 (permalink)
FTG-05's Avatar
My Photos: (25)
Correct.
Here's a pic of a plugged up oil cooler. Pretty much acts like a coolant filter when it's plugged up.
Old 08-10-2009, 06:09 PM   #7 (permalink)
dikkstarr's Avatar
Yeah the oil cooler is a coolant filter, just a very expensive one after it gets plugged!!! The add on one is better, and cheaper.
2004 F-250
Old 08-10-2009, 06:33 PM   #8 (permalink)
Just ordered the kit for my 06 F250. Its actually in the shop for the first time @ 76k miles because it was loosing coolant for the first time since brand new. How do I make sure Ford does what they are supposed to with the EGR and oil cooler?
2006 F-250 4x4 SC XL 6.0 3.73 (103k miles)
HG & ARP @ 73k Miles / new oil cooler @ tear down
EGR Fixed Permanently, 4" Turbo Back, Amsoil Bypass, Coolant Bypass, SCT econo from DP
6" Lift w/ 35" Tires on stock rims
Tweintz is offline   Reply With Quote Quick reply to this message
Old 08-10-2009, 08:08 PM   #9 (permalink)
06yz125's Avatar
So you usually start seeing restrictions at 70-80K miles?
Old 08-10-2009, 10:02 PM   #10 (permalink)
FTG-05's Avatar
My Photos: (25)
The pic of the oil cooler that's plugged up that I showed earlier came out of an '04 PSD with 44k miles on it at the time the oil cooler was replaced.
Old 08-11-2009, 11:03 AM   #11 (permalink)
Strokin' 6.0's Avatar
It was the best money I ever spent on this truck. If OTR trucks have them, it's a good idea to run them on ours too.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
2012 Ford bed w/Factory Reese hitch option
4.10 TracLok
Dieselsite Coolant Filter
IH Fleetrite ELC
Blue Spring Update
43,956 miles - Replaced 6.0L
54,814 miles - Turbo
94,943 miles - Fan clutch
98,755 miles - FICM
127,057 miles - Aftermarket Alternator
154,120 miles - HPOP & Oil Cooler
168,514 miles - Radiator, water pump, t-stat & hoses
178,810 mles - #7 injector
181,807 miles - A/C Compressor
199,458 miles - Motorcraft Alternator
199,506 miles - FICM
199,521 miles - #1, #4, #8 injectors
Strokin' 6.0 is offline   Reply With Quote Quick reply to this message
Old 08-11-2009, 07:52 PM   #12 (permalink)
philhyde's Avatar
Where does one get a filter kit?
2006 F250 Crew Cab Lariat 4x4 6.0L
philhyde is offline   Reply With Quote Quick reply to this message
Old 08-11-2009, 09:23 PM   #13 (permalink)
FTG-05's Avatar
My Photos: (25)
Make your own or buy a kit. I've done both and installing the kit was far easier and not much more expensive, certainly not worth the time, IMO.
Most of the major diesel vendors have a kit. The on I like is from Dieselsite.com here: DIESELSITE&reg Products - Coolant Filtration Systems
Old 08-12-2009, 01:16 AM   #14 (permalink)
dwelch1's Avatar
My Photos: (5)
do you lose any coolant on the filter changes? should I pick a gallon up or just monitor the low level mark on the degaus bottle? my coolant filter kit came today.
2015 F-250 Crew Cab, Lariat, 4x4 Magnetic
380 miles so far.
Relaced My:
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter
My Truck
2004/1997 Powerstroke Pics, Ford 9N Tractor,6.0 Bible
dwelch1 is offline   Reply With Quote Quick reply to this message
Old 08-12-2009, 07:31 AM   #15 (permalink)
Supporting Member
scrimshaw's Avatar
I have an 07 still under warranty - does anyone know if Ford sees the installation of a filter kit as an excuse to void warranty?
2007 F350CC 6.0L,
XLT, Wedgewood Blue/Silver,
Auto, LB, F/x Camper option,
upfitters, Tow Command System
scrimshaw is offline   Reply With Quote Quick reply to this message
Security Question
*Required, this field is not shown to others. "While balancing on a piece of wood, two inches by four inches known as a 2x4, john and his friend sally both spotted a dalmatian inside a truck with sirens, headed to put out a fire. State what the 2x4 is made of. "
Insurance
Please select your insurance company (Optional)
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
