Alternate fuel question?? - Diesel Forum - TheDieselStop.com
Old 05-17-2010, 05:47 PM   #1 (permalink)
I used to run a 70/30 mix of used filtered transmission fluid in my 7.3. does anyone know if it is safe to run this in the 6.0's. Will it mess up the ever so sensitive fuel injectors? Also opinions on methanol injection would be accepted...Thanks
lamma007 is offline
Old 05-17-2010, 06:01 PM   #2 (permalink)
wow 70 30 you have a tranny shop?
thats alot of fluid. i have never seen anyone run that much.what was your mpg like?
i myself would not go that high in a 6.0 the EGR i think would be a problem.
06 4x4 cc amarillo loaded 20" wheels stock. sold to a lucky man,2000 f350 ex.cab propane 4inch s.s.exht,diablo 80hp chip .
http://www.photoserver.us/is.php?i=143695&img=redo2.jpg
ahurley is offline
Old 05-17-2010, 07:00 PM   #3 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
tranny fluid will strip away lubrication. i would be concerned with the injectors experincing excelerated wear... obviously this would void the warranty from ford if you have it still and make the fuel filters and the tank have a red pigment causing them to think you are running red dye fuel... which would get you fined. possibly a larger fine since the atf is not taxed and not approved for otr fuel. other than those issues i would expect to change the fuel filters at 5k intervals for the first couple of oil changes to see what they look like. i personally wouldnt run atf thru my truck. as far as methanol i would use no more that 50% something closer to 70/30 70% water.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 05-19-2010, 11:29 AM   #4 (permalink)
Sorry I didn't specify, 70 diesel 30 ATF. The mileage stayed the same but it did smoke a little more under heavy load. When I got rid of the truck it had 280,000 miles and running strong. Ahurley, I have a Rhino Linings dealership so the local tranny shops are more than willing to fill a drum up for me.
lamma007 is offline
Old 05-19-2010, 09:24 PM   #5 (permalink)
OT
OT's Avatar
Lam..didn't see atf, but other info. here Lubricity Additive Study Results - Diesel Place Don't know about methanol inj. on 6L (if that's what your asking) But, I think the alcohol content would be harmful. JMO!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
