Old 03-03-2009, 05:49 PM   #1 (permalink)
Roosterq's Avatar
Am I right?
The "Check Gauges" indicator came on, in my dash (Not check engine) and all the gauges seem to be working except the Oil pressure gauge. The needle seems to be stuck in the middle of the gauge, even when it is off. I have a mech oil pressure gauge so I know I have good oil pressure. Could the "Check Gauges" indication be caused by a bad oil pressure switch?
Roosterq is offline
Old 03-03-2009, 07:29 PM   #2 (permalink)
the gauge should be down not in the middle if the switch was bad, sounds like you might have a problem in the cluster
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 03-04-2009, 09:01 AM   #3 (permalink)
Roosterq's Avatar
Thanks, That was my second opition, and someone who works on these fairly often suggested the same thing late yesterday afternoon.
Roosterq is offline
