Another engine temp question - Diesel Forum - TheDieselStop.com
Old 08-29-2009, 01:08 PM   #1 (permalink)
For all you that have devices to read from the OBD-II port, howmuch hotter do you run in city? Currently I run 194-198 on highway at 70 mph, outside air temp 72*, AC -off. When I go to residential streets near house temps rise to 207*. No hard acceleration, just typical residential stop signs, and 25-30 mph speed. Does that seem right?
Oil cooler has been changed by dealer, EGR tested (passed) and plugged, heads tested and passed.
Doug
2007 F-350 Crew Cab DRW 4X4 4.10LS, MBRP 4" Cool Duals turbo back, SCT/ custom tunes from Elite Diesel, Autometer gauges EGT, Trans, Fuel Pressure, MSD Dash hawk OBD II reader for ECT,EOT,Voltage and Boost, Dieselsite coolant filter
dougjpr is offline
Old 08-29-2009, 01:24 PM   #2 (permalink)
Forgot to mention, truck has approx 3500 lb in bed.
dougjpr is offline
Old 08-29-2009, 03:33 PM   #3 (permalink)
What sensor are you monitoring to get those temps?
I average with 13K in tow.
Between 188 - 193F on the coolant sensor.
I haven't had a chance to monitor a heavy climb since the purchase of my ScanGauge II but will a week after Labor day when we head up north.
2005 DWL SB Crew 6.0 w/tow command, 4:10 rear end. FICM Repair @75k, (Gift from 7/200 coverage) ScanGauge II, Banks Ram air intake, Coolant Filter, Banks exhaust, ARP Bolts. The whole OASIS would never fit here!
Munfrobie is offline
Old 08-29-2009, 10:17 PM   #4 (permalink)
using a MSD Dashawk.
dougjpr is offline
