antifreeze for 6.0 psd - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 10-11-2008, 07:33 PM Thread Starter
has anyone used or can i use prestone heavy duty antifreeze in my 03 6.0 psd..i know i can use the extended version heavy duty..but what about the regular heavy duty..whats the difference..thanks
2003 F250 fx4, shortbed crewcab, 6.0psd, Red, 6" donahoe lift, Bilstein 5100 shocks with dual front hoops, procomp exteme m/t 35 tires on Helo max 8 wheels, ATS extreme painted flairs, linear extreeme bed liner, Banks complete monster exhaust, Banks 6 gun tuner with pda, Airraid intake, Banks intercooler , Alpine cd with 4 6x9 polk audio db690 speakers and 3 jl audio 10w6 subs with hifonics bdi1606 amp, Hifonics 400, clarion eq, tinted windows, chrome running boards, Triglass tonneau cover. chrome door handles and fuel cover, aluminum grill and foglight grill insert, dual steering stabilizer,..
rkfguard is offline
post #2 of 5 (permalink) Old 10-11-2008, 07:55 PM
Some good info in the following thread:
Quick coolant question
'04 Excursion EB, 6.0 PS, 4X4, Magnaflow Performance exhaust, Isspro gauges (boost, pyro and tranny), Bilsteins, aFe intake, front and rear leaf spring upgrade w/ bags, 30mm rear sway bar, SCT Xcal2, Red-Head box, Jordan brake controller, Arctic Fox 29V - 20,420# GCW, Everything haulin' me, the wife, the 5 Amigos, Millie and Yogi (our 2 Berners).
Stewey is offline
post #3 of 5 (permalink) Old 10-12-2008, 12:22 AM Thread Starter
so as long as i use an antifreeze with sca or fw16 additive, i should be good to go..but whats the difference between the extended and plain heavy duty type
rkfguard is offline
post #4 of 5 (permalink) Old 10-12-2008, 09:05 AM
Do not use antifreeze with additives (SCA) in the 6.0L. The FW16 was for previous engines. These additives will react with the Motorcraft Gold coolant and cause problems.
Here is a good read on the technical reasons behind using a specific antifreeze:
Coolant flush and refill procedure? - Ford Truck Enthusiasts Forums
Mark
bismic is online now
post #5 of 5 (permalink) Old 10-12-2008, 06:54 PM
rock_doctor's Avatar
Just use the Zerex G05 (and distilled water). You should be able to get it at most large autoparts stores. Just call around and price it. The wrong antifreeze and you will have pin sized holes form in the water jackets (due to cavitation).
rock_doctor is offline
