Anybody know the tricks of the cruise control on these 6.0s - Diesel Forum - TheDieselStop.com
Old 12-01-2006, 09:00 PM   #1 (permalink)
GruntTorque's Avatar
everytime I set the cruise on my truck when pulling my trailer in overdrive I can set it at 65 and it drops to say 62 and then mashes the throttle to the floor to catch up 65 and then wont shift back into overdrive. If I dont use the CC I can drive in overdrive for miles and miles its really frustrating on a long trips. Thanks in advance
GruntTorque is offline
Old 12-01-2006, 09:30 PM   #2 (permalink)
HeavyAssault's Avatar
My Photos: (6)
Re: Anybody know the tricks of the cruise control on these 6.0s
I tend to hold down the "set" button till the truck is at the speed and accelerates a bit. Then I coast down to the desired speed. It is a fairly tempermental cruise control system.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 12-01-2006, 11:23 PM   #3 (permalink)
Smiley1's Avatar
I find that the trick is to turn on cruise and immediatley release the gas pedal. It seems to pick up right away for me. If I slowley release the gas pedal it will slow way down until I completely release the gas pedal.
All these years and Ford cant come up with a better cruise system. They get the trophy for the worst... and it seems to get worse...
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
Smiley1 is offline
Old 12-01-2006, 11:39 PM   #4 (permalink)
My Photos: (16)
Mine is a pain!!
2006 F-250 CC SB FX4 6.0L Metalic Silver Lariat.AFE 4" Turbo Back Exh. XM Radio.LED Running lights,2.5" Tuff Country kit,35 12.5 Toyo MT's,AIC,Huskey Liners,Line X. <font color="red">My F250 </font>
1965 White Freightliner NH250 Cummins.
2004 Hyundai Santa Fe V6 Canyon Red
TugEngineer is offline
Old 12-01-2006, 11:44 PM   #5 (permalink)
you can over ride the cruise by applying throttle when going up hills to keep it from reducing speed and downshifting... also take it out of tow haul it wont downshift as quickly...
2003 f250 crew...afe intake, gauges, 4 inch turbo back, sct tuner by Tadd , suncoast tranny.. Elite diesel studs and fire ring, stage one fuel kit, stage 2 injectors, Spearco intercooler.. ....aka HOT PURSUIT HAULER...
2006 badlands built moon buggy rock crawler rear engine turbo charged eco-tech.... aka HOTPURSUIT...FOR SALE pm for details
all vehicles running MAXXIS TIRES
hotpursuit is offline
Old 12-02-2006, 01:08 AM   #6 (permalink)
I personally don't use cruise control while towing. I like having a bit more control over my speed.
Mark
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP Exhaust, FluidAmpr, Elite Regulated Return (55 psi), Airdog, Weld Evo Velociti & LT285/75-16
Built: 11/03/03
4x4Mark is offline
Old 12-02-2006, 02:36 AM   #7 (permalink)
LariatPSD's Avatar
My '98 Mustang has THE best functioning, easiest to use, cruise control I have ever used. It stays within 2 MPH of where you set it and each tap (accel or coast) = 1 mph adjustment. Doing 80 and want to go 85? Tap up 5 times quickly. I've never gotten a BMW's CC to work like it should. Anyone driven a Chevy with the magical 300 function turn signal lever. Those are a total pain to use. I don't believe Ford has the worst.
Yes the Powerstroke CC's are a bit sloppy being that it doesn't understand the turbo's boost and lag. And if your truck is chipped, forget it below 60 mph, you'll be stuck in a permanent up-down-up-down oscillation from 'over boosting' on accel.
'06 F350 Lariat FX4, Crew Cab, Long Bed
4" Superlift w/Bilsten 5100's
LariatPSD is offline
Old 12-02-2006, 02:47 AM   #8 (permalink)
My Photos: (16)
My 97 Crown Vic had amazing CC. Worked like the Mustang
Old 12-02-2006, 09:13 AM   #9 (permalink)
my "trick" is to get to the speed I want to cruise at on a flat part of the highway ( no hills ) and hit set without my foot on the accelerator. It works better than trying to set it on a hill with your foot on the pedal.I do notice it gets lazy on hills which is a PIA! I think they could have done a better job with it. I have had hundreds of NEW fords (as a company car) and none of them seemed to have a mind of there own like this one.I don't let it bother me I am getting more use to the little quirks this truck has. I also have to remind myself from time to time that I am driving a 1 TON full size pickup truck not a 1/2 ton POS!!! or a sportscar. [img]/ubbthreads/images/graemlins/eek.gif[/img] I think that sometimes we need to be reminded of that.
2005 F350 Reg Cab 4X4 SRW XLT 6.0 SOLD 1/31/08
2008 F250 SUPERCAB 4X4 SWB SOLD 10/23/2011
2011 F250 CREWCAB SWB 4X4 6.7/AUTO XLT
dmags is offline
Old 12-02-2006, 09:24 AM   #10 (permalink)
william_04_X's Avatar
i do just the opposite..i'll get to my target speed, set the cruise, and gently ease off the pedal.
i'll be giving it fuel while the cruise is going through it's falling on it's face, where am i stage..as i'm easing off, it catches up and then it's smooth until the next hill.. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
04 EB X w/03 PSD
william_04_X is offline
Old 12-02-2006, 09:42 AM   #11 (permalink)
I was having problems with the cruise on my 04 when it was new. Unlike my other Ford pickups and products the thing would decelerate downhill about 5-10 MPH and then go WOT up the hill and overshoot the setting, which drove me nuts and anyone following me. I had it reflashed and never had a problem since.
2004/04 F250 4x4 CC SB Lariat, 6.0L Torqshift, Dark Toreador Red/Silver, moon roof, heated seats, tubular steps, Access Cover, Keyless entry, FX4
SoDakMac is offline
Old 12-02-2006, 09:55 AM   #12 (permalink)
It seems that the big problem is that the computer in the PCM is on the edge of being over worked. It is probably too small for the job required. Look for a completely different system an the '08's.
2003 F250, 6.0L, Torqueshift, short bed, supercab, 4x4, build date 1/05/03 (stock)
1997 Lincoln Town Car
33 ft Newmar Kountry Star 5er
jsglick is offline
Old 12-02-2006, 11:12 AM   #13 (permalink)
FamilyRide's Avatar
Mark
I absolutely agree. I rarely, if ever use it at all.
I has to be something specific with a diesel motor and drive train control because I've never seen a gasser of any kind with cruise that didn't actually work well. Or I should say, recent gassers, not going back to the vacuum days... [img]/ubbthreads/images/graemlins/wink.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 12-02-2006, 11:21 AM   #14 (permalink)
My Photos: (6)
Resume is the worst on my truck. Must have been designed by a true moron. The 05e15 flash help a lot but it's a long way from being right.
05 F250 SD XLT Reg cab 4x4 Arizona Beige 6.0L PSD, AT, Advanced Security Group, ESOF, Fog Lights, Stabilizer Package, Tow Command System, Upfitter Switches, Aluminum Wheels, Cab Steps & Super Liner bedliner,Fumoto Valve, Air Lift Air Springs & Smart Air.
stewcon is offline
Old 12-02-2006, 12:28 PM   #15 (permalink)
Thats the same thing that I have done while towing with no problems. Hell, I even do that when I am not Towing and have not had any problems.
2006 F-250 Lariat PSD Fx4 Shortbed Extended Cab, 4" MBRP Cat Back (have the DP just not installed yet), Fumoto Valve, Viper 160XVL Remote start
Engine born on date- 5/13/05 (a Friday no less)
brnscofrnld is offline
