ARP studs one at a time without removing the heads
Hi I am going to replace the head studs on my 2006 f-350 6.0 diesel. How do you guys feel about doing it one at a time and not replace the H.G. I have 23000 miles on the truck. I will be taking it to Gillett diesel in bluffdale, UT. and this is how they do it if H.G are not blown.
I think it will be fine, i am going to do all 3 of my trucks this way, as long as you are 100 percent sure you have no HG leaks, there really should not be a problem, some people may say the other way, not to do it , so its your choice.
2011 KR Dually CC 4X4 Royal Red
2006 KR Dually CC 4X4 ,True Blue
2005 KR Dually CC 4X4 ,Dark Copper,sold 12/30/10
2005 Eddie Bauer Excursion 4X4 ,White
All purchased from Bobby Williams At Sunrise in Fontana
It is perfectly acceptable to replace head bolts in this manner. The studs however use a much higher torque than the TTY bolts. I would just ask how the shop intends on raising the torque to this higher value. It would be best if the studs were initially torqued to the value of the TTY bolt that they replaced and then use a torque pattern and incrementally raise the studs to their final value
2007 F350 XLT 4x4 SC 6.0 PSD No Mods *Traded*
2011 F250 XLT/FX4 4X4 CC 6.7L PSD
OK i pickup my truck on Friday 11/20/09 it is running great and the egt is lower by about 100 degrees. i will keep everyone updated on how the truck is running
thanks for the reply's
2006 KR f-350 CC 4X4 ,Dark Copper
I am confused? How did studding your block reduce EGTs? I see no relationship in the two. Did I miss something in this post?
2005 DWL SB Crew 6.0 w/tow command, 4:10 rear end. FICM Repair @75k, (Gift from 7/200 coverage) ScanGauge II, Banks Ram air intake, Coolant Filter, Banks exhaust, ARP Bolts. The whole OASIS would never fit here!
