Avg cost to making 6.0 reliable(bulletproof) - Diesel Forum - TheDieselStop.com
Old 11-08-2011, 09:40 AM   #1 (permalink)
Bully Joe's Avatar
I'm pretty new to the forum and diesels but have learned there are some key modifications that are recommended to prevent the issues that the 6.0 are prone to. I'm in the market for a 6.0 and thought it would be a good idea to compound a list of key mods and the average cost of them, for others looking to buy a truck or just brought a truck and want an idea of what they're looking at as far as cost.
If this has already been done just link me to it. I just did a quick google search, products aren't my suggestions just examples of what came up in search for price reference:
-Ford/Racor oil/fuel: $20-50
-ARP head bolts: $500
-Black Onyx head gaskets: $200
-Diamond Eye4" exhaust: $250
-Scangauge II: $200
-EGR delete kit: $300
I'm sure there's plenty I missed, hopefully others with more experience will contribute...
Bully Joe is offline   Reply With Quote Quick reply to this message
Old 11-08-2011, 01:21 PM   #2 (permalink)
Feedback Score: 2 reviews
-Scangauge II: $200
Joe
you have a good start but the list goes on
Stock Ford gaskets my understanding better than the Black Onyx
Coolant filter-http://www.dieselsite.com/2003-200760lcoolantfiltrationsystem-preservethelifeofyourwaterpump.aspx
ELC coolant-$80.00
Distilled water 40-50 gallons $30.00
Restore-Restore+--$60.00
Oil by-pass system--$300.00
Fuel pressues gauge and reg kit--$300.00
Oil cooler (maybe) $300.00
FICM Repair (maybe) $300.00 New $1100.00
2 New Batteries $250.00
To do the repairs $3000-$4000.00
I'm running out of $$$$$$
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline   Reply With Quote Quick reply to this message
Old 11-08-2011, 05:09 PM   #3 (permalink)
Bully Joe's Avatar
I figured I missed a boat load of items. Thanks for stepping in. Looks like I will need to tell the wife the truck will cost about $5k more than I plan to buy it for so I can get everything up to par.
Can we prioritize them in a couple of categories like what has the highest priority? I don't know enough to do it or to tell what can be done by a novice diesel owner and what should go to the shop...
Old 11-08-2011, 07:49 PM   #4 (permalink)
07PstroKe's Avatar
Send a message via Yahoo to 07PstroKe
Don't forget....
ARP head STUDS (Pretty sure that's what you meant)
Fuel regulator "update" (blue spring mod) $61.00 shipped
Programmer
P.S Aside from the head studs, most of the things can be done in your own driveway with basic tools. Before you go spending the money on labor....check for threads on these mods. A lot of us have done them ourselves, tons of great information, pictures, and advice.
Larry M.
2007 F-350 6.0 PSD MURDERED
6" Procomp stg II w/37" Toyo M/T's on rockstars
Edge Juice
Stacked 7" straight cut
Pioneer D2 Nav
Sinister Coolant Filtration
Amsoil oil bypass
Blue spring "update"
BD Power hose/clamp kit
CFM+ Intake
6.4 Banjo bolt upgrade
LMelilloiv@gmail.com
07PstroKe is offline   Reply With Quote Quick reply to this message
Old 11-09-2011, 11:40 AM   #5 (permalink)
07PstroKe's Avatar
Joe,
Depending on ones own "budget, priorities may change.
Exhaust is a fairly cheap but necessary upgrade to any diesel (including my Jetta TDI). You'll notice lower EGT's but not much difference when you drop the hammer.
EGR delete, again fairly cheap. But if your not mechanically inclined to get into the motor a bit, I don't recommend doing so without some research first. I perosnally have not done this mod to my truck, stock cooler has gotten me to 105,000 miles successfully. Why fix whats NOT broken?
Blue spring mod, a noticeable difference, can be done in about an hour or so even for a newbie. This is a cheap and very necessary mod.
Coolant filter, again fairly cheap, easy install. Just ordered mine, most expensive part is the distilled water and new coolant for the flush and refill.
There is more, but I think this is enough to start with. Good luck.
Larry M.
Edge Juice
Pioneer D2 Nav
Amsoil oil bypass
CFM+ Intake
Old 11-09-2011, 09:02 PM   #6 (permalink)
I would say, Coolant is the #1 mod needed, then fuel pressure blue spring, gauges (scan gauge) is fine. Then exhaust, coolant filter and probably a FICM repair (you may need this immediately, you will have to check the voltage. There are a lot of fixes needed to give you peace of mind, but they are great trucks.
2006 F250 King Ranch FX4 - (Build date Sept. 2005)
6.0L (Engine Build date Sept. 21 2005)
Dark Copper w/ Beige accent
Short Bed, Crew Cab, Sun Roof, Power Rear Window
18" KR wheels, Camper Package, Tow Command
Mods: Shaker 500 Stereo, Alpine MRV-F450 amp, Line-X, Edge Insight, MBRP 4" Turbo Back Exhaust, Diesel Site Coolant Filter, Blue Spring upgrade, Removed Ford Gold Coolant, Fuel Pressure Guage
ralderman is offline   Reply With Quote Quick reply to this message
Old 11-09-2011, 11:22 PM   #7 (permalink)
blackcell's Avatar
Could you gents elaborate on what you mean by exhaust and why is it a recommended upgrade? Thanks, I'm still in learning mode.
2012 F350 6.7L 4x4 Lariat Ultimate FX4, Chrome package, KR, Nav, SRW, CC, LB, 11.5K GVWR, 3.55 ELA, 20" wheels, Toyo MT's, Husky 26K hitch (Build date 12/2011)
2009 Carriage Cameo 35SB3, 12.4K dry, 36' Fiver
United States Navy Combat Veteran
blackcell is offline   Reply With Quote Quick reply to this message
Old 11-10-2011, 04:50 AM   #8 (permalink)
Bully Joe's Avatar
Originally Posted by 07PstroKe View Post
Joe,
Thanks for the suggestions. Seems like those are very elaborate mods and are pretty easy on the wallet.
All of those seem pretty easy for the most part. Not sure about the FICM repair...
Here's a video that can explain it better. Actually this guy has over 100 vids that I watched one day and I learned something from each one, not a bad idea for you to scan through all his vids.
EGR(Exhaust Gas Recirculation) delete mod
powerstrokehelp's Channel - YouTube
And here's a menu of all his videos, 179 of them...good info
Old 11-11-2011, 07:16 PM   #9 (permalink)
blackcell's Avatar
Bully Joe, awesome, thanks for links!
Old 11-12-2011, 06:17 AM   #10 (permalink)
At 120000 miles I blew the head gaskets. They milled the heads, new radiator, new Bulletproof cooler, ARP studs and a new serpentine belt. $5700. Last week at 150000 miles they had to replace HPOP and oil cooler and the FICM with the good fix. $3600. One thing I learned was the coolant is critical and you need to get the PH tested on a regular basis which my mechanic never did.
-2004 F-250 super duty diesel Lariat
-Torreador red with beige trim
-Fx4
-Ramsey winch
-H&K usp compact/.40 S&W
gleninaz is offline   Reply With Quote Quick reply to this message
Old 11-12-2011, 07:49 AM   #11 (permalink)
curly0909's Avatar
What is PH??? ive gotten quotes for 4k on a bulletproof from a 6.0L only shop... where r yall taking your trucks, holy crap, $5,700???
New: 2012 Ram 3500 cummins CCSB 4x4
9'6" Hiniker V-plow this year.
Also new tonneau Cover.
Retired: 2007 Crew Cab Short Box F250 Lariat
64,000 miles. Completely Stock!
Scanguage 2 Monitoring The Vitals.
Dad: 2011 F-150 CCSB Ecoboost!
Bone stock!
2011 Dodge Durango
"Ya got Hemi?"
curly0909 is offline   Reply With Quote Quick reply to this message
Old 11-13-2011, 02:34 AM   #12 (permalink)
Check out this post
Informational post on 6.0 upper engine work
This will give you an idea of what everything cost me.
2004 F350 4x4 Crewcab Dually XLT, 6.0L V-8 Diesel 6-Spd H/D trans. Oxford White. 4.10 Limited Slip Axle, Advanced Security Group, Bright Polished Cab Steps, Sliding Rear Window, FX4 package, 6 Disk CD Changer, Fog Lamps, Cloth Captains Chairs, Privacy Glass.
B&W Turnover gooseneck ball hitch and five leaf overload pack added.
4" Exhaust, SCT tunner running the 65hp heavy tow tune!
New headgaskets, head and valve job, ARP Studs, Injectors replaced, Upgraded oil tubes, EGR Delete, New oil cooler, New manifolds, Blue spring fuel pressure kit, new 850 batteries, and ScanGaugeII.
6.4L Banjo Bolts
tlcregger is offline   Reply With Quote Quick reply to this message
Old 11-13-2011, 04:26 AM   #13 (permalink)
Great thread! Also my favorite view.
1bbcd5 is offline   Reply With Quote Quick reply to this message
Old 11-27-2011, 08:51 AM   #14 (permalink)
Joe,
I'm a little late to the party with my 2 cents, but I'm "bulletproofing" my 6.0L now. At 122K miles I blew my EGR cooler, which was evident by the white billowing smoke from my exhaust and confirmed by the coolant in my Y pipe and intake manifold. These are the repairs I have done and those I am in the middle of doing in chronological order. (It may not be the best order, but it worked for me):
Superchips Flashpaq, used and unlocked for $200 (but I'll be upgrading to a SCT X3)
4" Dynamax exhaust, about $550-600 from NAPA
Blue Spring upgrade, $60 from Tousley Ford (easy 45m upgrade)
EGR Cooler and Oil Cooler Kit, $2200 from Bulletproof Diesel
ARP Stud Kit with all the injector ORings, $1089 from Bulletproof Diesel
Professional Kit (HPOP upgrade, turbo drain upgrade, oil pump switch, misc orings, gaskets, filters, etc) $220, from Bulletproof Diesel - spent so much at BPD they gave me a free jacket.
Waterpump with CNC aluminum impeller, $250 from Bulletproof Diesel (this one you don't have to do, I just didn't want it going out after a coolant flush and end up wasting all the money on new coolant)
Once its back together I'll do a coolant flush for about $100 (water, Restore, coolant, Fumoto valves, etc) and install a coolant filter for about $170. I have the typical rough start in cold weather, but I think a FICM reflash will take care of this.
I am fortunate enough to have a place to work on my truck with a lift, so I pulled the cab to do it all and did the labor myself. I will have about $5000 into "bulletproofing" my truck when I'm done...until I blow something else up on it.
Bare in mind, I'm pretty new at this and am, by no means, a mechanic. There are certain to be some differing opinions on this forum, but if you budget for about $5000 in parts and a few more $$ in labor you will have a pretty nice truck.
Keep reading this forum. There is a lot of great information on here, but if you're doing the work yourself you may also want to purchase a service manual ($180 on Amazon). You can find most of the manual here and there on this forum, but its convenient to have one on your workbench.
I was told not to buy a 6.0L when I bought mine, but despite the drawbacks its one fine truck. Good luck.
2006 F350 6.0L Lariat Crew Cab Long Box FX4
SuperChips Flashpaq / SCT X3
DynaMax Turbo Back Exhaust
3.5" Level Kit with 35"s on 18" Helo
Blue Spring upgrade
BulletProof Diesel EGR
BulletProof Diesel Oil Cooler
ARP Studs
RetroFit HIDs
Ranchhand Grille Guard w/ Smittybilt Winch
Scanguage II
One Partridge in a Pear Tree
NEB_DIESEL is offline   Reply With Quote Quick reply to this message
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
