Bad Fuel Injectors - Diesel Forum - TheDieselStop.com
Old 09-04-2009, 06:24 AM   #1 (permalink)
Exclamation Bad Fuel Injectors
I have been told that I will have to remove the cab in order to access the rear injectors. Is that true? I am doing this my self. Does anyone have any advice?
phadidon is offline
Old 09-04-2009, 10:53 AM   #2 (permalink)
John Anderson's Avatar
You don't have to remove the cab. The back two on the passenger side are kind of tight coming out, but it is no big deal. Just make sure you have a long t40 torx bit to reach the injector hold down bolts.
05 F-250, 4x4, 5.4, Auto, stock except custom tune and dual exhaust
04 F-350 CC, 4x4, Dually, Auto, 6.0, studs, egr delete, 4" exhaust, under construction
99 F-350 Reg Cab, 4x4, 7.3, 6-speed, Twin Turbo, Big Oil, 350CC injectors, South Bend Dual Disc, Lots of boost
I was Johnboy, Johnboy2, and Johnboy3 before losing my password three times. Member since 6-19-99.
John Anderson is offline
Old 09-04-2009, 04:26 PM   #3 (permalink)
Banned
What John says... and, for Gawds sake... stop listening to whoever you were talking to...
GrampyJim is offline
Old 09-04-2009, 08:39 PM   #4 (permalink)
You will need beer, tho.
dieselpartsman is offline
Old 09-04-2009, 08:41 PM   #5 (permalink)
speedrcr78's Avatar
You can do the passenger side with out removing the AC stuff as well. You just need a t-30 bit only and 1/4 inch ratcheting wrench. There are two bolts on the oil log that need to be removed using this setup. Just be careful that you dont drop the bit into the head.
speedrcr78 is offline
Old 09-04-2009, 11:38 PM   #6 (permalink)
Thanks for the help! I will be starting this project in the morning, wish me luck
phadidon is offline
Old 09-05-2009, 09:12 AM   #7 (permalink)
Btw, a 3/4" socket works fantastic to release the injector wire plugs from the head. Good luck.
Old 09-08-2009, 08:24 PM   #8 (permalink)
Truck is running good now!
Thanks to you all for the advice. Put three new injectors in it and it is running great now...
phadidon is offline
