Bad/strong exhaust smell at idle - Diesel Forum - TheDieselStop.com
post #1 of 24 (permalink) Old 11-16-2005, 01:08 AM Thread Starter
Lately i noticed the exhaust smell of my truck has gotten really strong at idle. I know it's a diesel but it's getting really bad.
Any suggestions on why it doing this.
Rwhat is offline
post #2 of 24 (permalink) Old 11-16-2005, 01:49 AM
Re: Bad/strong exhaust smell at idle
well, you have no info here, but I know for awhile there was a problem the y pipe cracking, or being cracked, something. it would cause exhaust into the cab.
04 6.0, volant intake, 4 inch exhaust, NOR-CAL TRUCKS custom 13 inch lift, GOLDENFOX CUSTOMS interior-dark gray suede insets with light gray leather, GOLDENFOX CUSTOMS paint-two tone candy with stripe, NO BADGES, KAR TUNZ custom stereo, 20 inch chrome weld commandos with 40" toyo's, 4:56 gears, and some fast stuff by DJ
goldenfox is offline
post #3 of 24 (permalink) Old 11-16-2005, 02:20 AM Thread Starter
I understand the y-pipe deal. I'm talking about a really bad diesel exhaust smell with the drivers and passanger window down. I have stock exhaust and no mods. Lately the smell has gotten bad, like a gasser running rich.
Rwhat is offline
post #4 of 24 (permalink) Old 11-16-2005, 05:29 AM
Do a search here and you'll find a lot of info. Take it to the dealer. Most often it's a Y-pipe leak or a manafold leak. Mine is doing the same thing and getting worse. Initially there was no smell at all, now it's very strong. After 3 repair attempts, I'm in mediation and may end up going lemon law.
2005 F-250 King Ranch Crew Cab.
RBachman is offline
post #5 of 24 (permalink) Old 11-16-2005, 07:09 AM
Mine does it also.
I had the turbo down pipe replaced and it still does it.
I will end up taking it back to the dealer sometime soon.
2005 F250 Lariat FX4 Crew Cab. NO MODS = NO PROBLEMS. (Approx: 65k miles) Shaker 500!
FHAREN is offline
post #6 of 24 (permalink) Old 11-16-2005, 10:39 AM
FamilyRide's Avatar
Maybe different fuel (blended) but diesel exhaust does smell like well, diesel exhaust and with the windows down, you'll smell it more. You should smell mine with all 4 windows down and both rear quarter windows opened and I come to a stop and the wind is jst right. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #7 of 24 (permalink) Old 11-16-2005, 12:01 PM
ritschner's Avatar
Send a message via AIM to ritschner
It is that time of year. With colder temperatures the warm exhaust will tend to rise more and manage to find its way into the ventilation system. This is made worse by the fact that colder starts means more unburned fuel in the exhaust after start-up and cold mornings usually mean still air. You need to point the truck into a light breeze to see if it is an exhaust leak problem. An exhaust leak will generally give you the smell even if the truck is pointed in a slight breeze.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Bilsteins, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB, Accufab elbow, Edge Attitude CS, Blue Spring Mod, DCPower 185a alternator, Rebuilt FICM, STC and Standpipe update, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
post #8 of 24 (permalink) Old 11-16-2005, 03:03 PM
Hey, I have an '04 and the exhaust smell is getting terrible in my cab. It has been that way since I bought it but is worse now. Guess I need to go back to the dealer. [img]/ubbthreads/images/graemlins/vomit.gif[/img]
2004 F250 Super Duty 4X4 6.0L Crew Fx4
flyingisbest is offline
post #9 of 24 (permalink) Old 11-18-2005, 06:25 PM
I have an 06
and when I stop at a stop sign/light or anywhere
there is a terrible exaust smell with the windows up
even if there is a breeze
My 2000 was never like this
hamp is offline
post #10 of 24 (permalink) Old 11-18-2005, 07:50 PM
We've got to get this problem figured out.
My 05 is the same way. Its going to the dealer over Christmas break.
FHAREN is offline
post #11 of 24 (permalink) Old 11-19-2005, 09:51 PM
I took a look under my engine and I can see that not only the downpipe left side connection to the exhaust pipe is showing evidence of blowing black soot, but half the manifold to head connections (both sides) are doing the same. Shame, shame, shame on Ford for such a silly problem. All for the sake of saving on a few cheap gaskets. Stinks to high heaven can't wait to get it fixed.
post #12 of 24 (permalink) Old 11-20-2005, 12:41 AM
I love the smell of diesel exhaust in the morning. It smells like.....victory! [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
"The Green Goblin"
2008 F-250 4x4 Lariat Super Duty Diesel Crew Cab
Amateur Radio W4RLR
Richard L. Ray
Sewanee, Tennessee
rray32539 is offline
post #13 of 24 (permalink) Old 11-20-2005, 09:50 AM
My new 2006 has exhaust smell in the cab about 30 sec after startup with the windows closed. Seems to get better after it warms up. I guess its off to the dealer!
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #14 of 24 (permalink) Old 11-20-2005, 01:49 PM
as long as the diesel smell is out the back of your exaust and not the front YES it is a good smell BUT when you are overcome by it in the cab it is not!!!!!!!
hamp is offline
post #15 of 24 (permalink) Old 11-20-2005, 01:51 PM
Yes, I get exhaust fumes tin the cab too. I think it started after they replaced the turbo at 34000 miles. Will go to the dealer on Wednesday.
Feb.03 F250 6.0 diesel CC FX4 SB TRQ.SHIFT
Avocado_Farmer is offline
