Bar's Leaks or Stop Leak. OK for a 6.0? - Diesel Forum - TheDieselStop.com
Old 07-06-2011, 04:31 PM   #1 (permalink)
stoverbro's Avatar
A couple years ago while changing out my water pump pulley, I snapped the nub off of the radiator that the small hose to the degas slips on. I fixed it with some parts I had laying around. It has been fine for the last couple years but after a coolant flush it developed a pinhole leak. I know the factory system has some type of stop leak pellets in it but I don't want to hafta pay ford prices. I need to replace the radiator but I seem to be only able to afford the "absolutely necessary" most of the time.....I've replaced my oil cooler before and don't really want to have to do it again anytime soon, so I'm gonna get some input first....
2010 Lincoln MKS Ecoboost Ultimate 60,000
2008 F-450 6.4 Crew Cab 4x4 Lariat 140,000 miles
2003 F-250 6.0 Crew Cab 4x4 Lariat 275,000+ miles
1997 Camaro Z28 Convertible (sold)
2002 Jeep Grand Cherokee Limited 180,000+ miles(wife totalled)
2001 60th Anniversary Grand Cherokee 170,000(rebuild complete)
1993 Ford Ranger 260k (finally beat to death, but still running)
1995 Coachmen Maxxum 37' 5ver
1949 Chevy Thriftmaster pickup 355 (sold)
stoverbro is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 05:47 PM   #2 (permalink)
I definitely wouldn't do it.
Stoverbro - Where did you confirm that Ford put stop leak pellets in at the Factory? That is an old rumor - never proven - at least I have never seen it backed up by anything official.
Mark
bismic is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 06:43 AM   #3 (permalink)
I wouldn't use stop leak in any vehicle especially one with a 6.0. The oil cooler in this truck is far too easily clogged to risk putting a clogging agent in it. If you can't replace it, JB Weld it or something but don't put anything into your cooling system which will be almost impossible to remove later.
- Karl Southeast NY
2003 F-250 Crew Cab Short Bed Lariat PSD 6.0 Automatic FX4 - Rebuilt oil cooler, Diesel Site coolant filter.
nylyon is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 09:42 AM   #4 (permalink)
FMTRVT's Avatar
My Photos: (16)
In a 6.0L they are knows as "Stop Oil Cooler".
Jack
Truck Pictorials on Facebook. Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is online now   Reply With Quote Quick reply to this message
Security Question
*Required, this field is not shown to others. "While balancing on a piece of wood, two inches by four inches known as a 2x4, john and his friend sally both spotted a dalmatian inside a truck with sirens, headed to put out a fire. State what the 2x4 is made of. "
Insurance
Please select your insurance company (Optional)
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
