Battery Favorites - Page 3 - Diesel Forum - TheDieselStop.com
Old 03-24-2009, 08:44 PM   #31 (permalink)
Gonna try two of these....
I am going to try two of these...
BATTERY MARINE DEEP CYCLE by Autocraft - Advance Auto Parts____
ctjahn is offline
Old 03-25-2009, 01:41 PM   #32 (permalink)
MikeL46's Avatar
My Photos: (14)
Originally Posted by ctjahn View Post
But, why?
I didn't think Deep Cycle batteries were the best for starting batteries. They simply tolerate deep discharge better than hi-amperage starting batteries.
After 5 years the stock Motorcraft batteries are working fine, and when I need replacements, that is what I'll get.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 03-25-2009, 02:52 PM   #33 (permalink)
Sorry....
Sorry....
I Hi-jacked the thread to find out about some batteries for my Toy Hauler.
Thanks!
Cj
ctjahn is offline
Old 03-26-2009, 09:26 AM   #34 (permalink)
69cj's Avatar
Originally Posted by CZDiesel View Post
Again, Costco... They have Optimas that were WAY less expensive then I could find anywhere else and they also have very good private labeled batts that have great warranties.
Optima's are not deep cycle batteries.
69cj is offline
Old 03-26-2009, 12:11 PM   #35 (permalink)
JW350's Avatar
My Photos: (29)
Thumbs up
I just installed a set of the Sears Diehard Platinum (Oddysey) batteries. Perfect fit into the battery trays. Engine cranks over with much more enthusiasm and my on-board air compressor runs like a bat out of hell.
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, Fox Shox, 37x13.5x17 Toyo Open Country MT on Weld Evo Velociti XT, 4.88 Gears, MagnaFlow Exhaust, AMP Research PowerStep, Auto Meter Cobalt Gauges (EGT Boost Trans), ScanGaugeII, Firestone Air Bags/Compressor/Tank, BulletProofDiesel EGR Cooler, Valvoline lubricants, Final Charge Global ELC, DieselSite Coolant Filter
JW350 is offline
Old 03-26-2009, 12:34 PM   #36 (permalink)
CAMPINGTOM's Avatar
I put Sears Diehard Golds in mine about 2 years ago and have been happy with them.
2005 F-250 6.0
4" Straight Pipe, CCV Reroute, Coolant Filter, EGR Delete, Insight Monitor, SCT X3 (Tuned by Innovative)
Stock head bolts, injectors and turbo
CAMPINGTOM is offline
Old 03-27-2009, 02:30 PM   #37 (permalink)
CZDiesel's Avatar
Sure they are... Optima "Blue" top 34M Marine deep-cycle. And guess what? You can buy them at Costco.....
2004 F-350 4x4 CC DRW
6.0l all stock
105k no problems, clean oasis
Snug-Top Shell
Bed Rug
ARB Front Bumper
Rough Country leveling kit
Rough Country Nitro Shocks
Power Slot Rotors
EBC "Green Stuff" pads
24' Haulmark Jobsite
2007 Arctic Cat 650H1
CZDiesel is offline
Old 03-30-2009, 08:36 AM   #38 (permalink)
I've had Dura-last Gold's in mine for about a year now, work great.
'06'F-350SD,6.0,Lariat,CC,SB,off-road4x4,darkshadow gray w/blacktutone,SCTx-cal tune
hvyduty is offline
Old 03-30-2009, 11:28 AM   #39 (permalink)
Strokin' 6.0's Avatar
+1...I have one in my Airstream. Only had one problem with them....first one I installed in 2005 went dead over the winter of 2006, while the trailer was in storage. When I put it on the charger in 2007, it overheated and blew the little gray piece on top and vented....in the middle of the night. I thought I had a gas leak and freaked out.
This one has given me no problems in two years.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Strokin' 6.0 is offline
Old 04-02-2009, 12:57 AM   #40 (permalink)
jspd234's Avatar
blue top in my boat, red top in my yota and a blue top in my trailer!!
06 F350 xlt sport fx4 srw lb cc 6.0 at afe pg7 cai & accufab polished power elbow, zoodad, dieselsite trans filter n coolant filter, fumoto, 4" turbo back exh. readylift 3.5" lift, 17" atx teflon thugs 315/70 firestone destination mt's. jvc cd dvd sirius head unit with 4 infinity kappa speakers 4 channel infinity amp 10" jl console sub 500 watt jl amp microvision dvd & headrest monitors 4 the kiddies in back!
01 chevy monte carlo ex-nascar southwest tour car raced in the american stockcar challenge(2007 champion!!)
02 sanger V210 black scorpion 330hp 2 fat sacks proflight tower 4 infinity 6x9's rf400 watt amp 12w7 jl sub rf 1001bd clarion amfmcdsirius head unit 4 clarion marine speakers 5 ch hifonics amp 10" bazooka sub encl firing a jl 10w3
09 crf450x
06 drz110 4 tha kid
08 crf150f 4 tha wifey
07 intl 4300 dt466 allison century 612 wrecker alcoa's
04 ford F650 xlt supercab 4dr cat C7 allison century 21 ft carrier alcoa's
97 ford F450 xlt sd 7.3 5 spd century 412 wrecker
jspd234 is offline
Old 04-03-2009, 09:15 PM   #41 (permalink)
Gotrox's Avatar
My Photos: (6)
I'm going for the Optimas, I "acquired" a yellow top out of a police car turn-in that I was going to put in my ranger. It wouldn't fit so I left it sit in my garage for 6 months, through a 0 degree winter. I gave it to my dad for a project s-10 and it started a monster 350 with no charging. I was very impressed.
2003 F-350 - 4x4, 6.0L, Auto, 52250 miles, Straight-piped, AFE filter, ProSport gauges, leveled, pro-comp 16x10s, 35" Nittos
Gotrox is offline
Old 04-03-2009, 11:45 PM   #42 (permalink)
heavyduty's Avatar
i have the 2001 with my original motorcraft batteries with 140k on truck hows that for long lasting batteries.
1999.5 F250 4X4 Automatic crew cab xlt,harpooned tank,,aem brute force intake, Rancho 9000 shocks, 5406 rancho steering stabilizer, magnaflow dual stainless exhaust, radiator filter, build date 12/08/98
heavyduty is offline
