Battery light stays on: '04 F350 - Diesel Forum - TheDieselStop.com
Old 12-04-2008, 05:10 PM   #1 (permalink)
My battery light came on the the day so I took it down to Walmart where they were purchased by the original owner. They replaced the accessory battery and said the engine one was ok.
The battery light is still on, any ideas as to why?
Thank you.
Billsman is offline
Old 12-04-2008, 05:34 PM   #2 (permalink)
klhansen's Avatar
My Photos: (169)
There is no "accessory battery" or "engine battery", both are connected to the same loads in parallel. If you have a bad battery, both should be changed at the same time, as the weaker old battery will drag the new one down.
Apparently they didn't give the charging system a good check, although they may have tested the batteries separately. You can do a rudimentary check with a voltmeter. If you don't get 14+ volts at the positive battery terminal when the engine is running, your alternator isn't putting out the proper voltage.
Your problem may be with the alternator and not the batteries. Also, a proper battery test is done with a fully charged battery, not one that's been discharged.
You may want to take it to a REAL battery shop, not a chain retailer like Wal-Mart.
Hard or no-start? Check Here
klhansen is offline
Old 12-04-2008, 07:30 PM   #3 (permalink)
rock_doctor's Avatar
The alt is bad. Find a alternator shop and have it checked asap.
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
