Re: Bed Plate Leak?
Bed plate leaks have been frequently misdiagnosed as rear main seal leaks, so I would question how the dealer is sure that it is the bed pan. To properly diagnose a rear main seal leak or bed plate leak, the transmission would have to be dropped after the truck had been driven with dye added to the engine oil. Make sure that you know exactly where the leak is comeing from, to avoid disappointment. To fix the bedplate leak, the engine has to be pulled, which is no small task. Find out if the dealer has done this before. To do it properly, the entire front body should be removed. Lotsa parts to come off and go back on again.
I would not buy the truck until the repair is done.
2005 F350 Super Duty extra cab Lariat Automatic, 4WD,FX4, dark Torreador Red with ARE cap (Ford buyback replacement for a leaky 03 XLT). 2005 F350 XLT Crew Cab Dually, 2004 F250 XL Super Duty reg. cab, 2005 F450 Box, 2005 F450 Dump bed, 2006 SLT Supercab dually, 3 2006 F550 supercab Dump beds, Custom 2006 F550 4 door Lariat 4X4 super hauler,2 2008 F450 crew duallies (and a whole lot of HD diesel equipment), and a 2006 Z06 for fun.
