Bent Pushrod - Replace Follower? Also Cracked Pushrods - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 11-05-2010, 04:43 PM Thread Starter
'05 F350 6.0L - So apparently in my hast to put everything back together after the ARP studs, injectors and Oil Cooler intstall, I did something wrong and have ended up with a bent pushrod.
Also while I was extracting the pushrods, I noticed that a couple of others seem to have cracks - one that goes almost completely around the pushrod and the other about half way around. both cracks are a little bit below half way down the pushrod, one on the same cylinder as the bent pushrod #4, the other on #2 Cyliinder.
So 2 questions:
When I insert the other pushrods into the slots it feels almost as though there is a seat that they fit in to, but when I insert the new pushrod into the slot that had the bent pushrod, I do not get that feeling - should I replace the valve tappet?
Question 2 - I am replacing all of the pushrods on this head regardless, but are these cracks normal? and should I replace the pushrods on the other head?
Harely350 is offline
post #2 of 8 (permalink) Old 11-05-2010, 05:09 PM Thread Starter
Not sure where I got the work Follower
So not sure where I got the word follower - but its my first diesel, so thinking maybe they called tappets differently in this world - sorry
post #3 of 8 (permalink) Old 11-05-2010, 05:54 PM
I double and triple checked and checked again when i put my pushrods back in. There were a couple that had a hard time finding the right slot to go back in probaby because of the angles. Just take your time and make sure you get it in the the right place. Not sure about the cracks, but that doesn't sound normal to me.
06 F-250 x/c 4X4 sb 17" alloy wheels. Tri-fold tonneau cover, weathertech vent visor,Ford floormats and splash guards. HarleyD headlights, Duplicolor bedliner coated bumpers, 08 rear bumper and taillights, herculiner rocker panels, XM radio, bosch wipers, Recon smoked cab lights, Edge Insight w/EGT probe, winter front.
06/10 ARP studs, turbo back silverline, new head gaskets, new oil cooler, upgraded turbo drain, fuel pressure reg upgrade, coolant filter, high idle mod, harpoon mod, pre-pump spin on fuel filter,ELC coolant, 6.4 banjo bolts, CCV reroute.
Truck weight empty fueled up, 4440 Front, 3040 rear, 7480 gross. Hex VXCF4,
SCT w/customs tunes from Vivian at Quick Tricks and Matt @ gearhead
worldwide73 is offline
post #4 of 8 (permalink) Old 11-05-2010, 06:41 PM Thread Starter
Thanks worldwide73. I took my lighted magnet and stuck my head down there to see if I could see anything and it looked like there was something in the way. I was actually able to get the pushrod to go down at an angle and then move it to the left with a slight resistance and feel it seat like the others, so I am thinking that there is something in the way.
I am going to pull the head off - I think it is the best course at this point and a lot less work to pull the rest back off than if I put it all back together and then something is still wrong.
Will check back in when I get it apart. Ordered another head gasket
post #5 of 8 (permalink) Old 11-05-2010, 06:47 PM
69cj's Avatar
Another tip from one of the techs, Cheezit, always turn the engine over by hand a couple of revs before using the starter.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
post #6 of 8 (permalink) Old 11-05-2010, 07:01 PM Thread Starter
Yea - I wish I had cheezit's knowledge and experience. I've read a lot of his stuff and tried to abid by his suggestions. It's just hard to justify the tools to my wife after spending close to $5K for parts when there wasn't anything wrong with the truck to begin with. She doesn't care how much time I spend on it, just dont dip into her spa money!!!
post #7 of 8 (permalink) Old 11-05-2010, 09:55 PM Thread Starter
So head is off - Head gasket is ripped and bent around where the push tube goes through it - that is probably what I saw. Also the plastic fins at the bottom just above the lifter - they look like they collect and focus the oil back into the hydraulic lifters - the right side of the one where the push tube was bent is torn. I will take pictures and see if I can get those out later this evening - My wife has a web site - maybe she can put them out there and I can use her URL to point to them.
post #8 of 8 (permalink) Old 11-06-2010, 02:52 AM Thread Starter
OK - Heres the pics
First are the push tubes - top two hace cracks just left of center.
Bottom one is FUBAR
2nd shows head gasket tear on push tube tab
3rd shows lifter tappet follower tear on right
