Best Cetane Boosters - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 04-13-2011, 05:59 PM Thread Starter
I'm trying hard to find a good cetane booster to fix some problems with the 2 international trucks I drive(both have the 6.0l, one is a 2003 the other 2005) the local ford dealer has no idea what I'm talking about niether do the local parts stores, but I lucked out and found a bottle of Diesel Kleen at a truckstop, how well will it work?
Are there any better ones out there? maybe cheaper too since it sounds like I will have to use it every fill up?
2002 F250 7.3L
2003 IHC 4200 6.0L
2005 IHC 4200 6.0L
classictruckman is offline
post #2 of 20 (permalink) Old 04-13-2011, 06:42 PM
Band_Member's Avatar
My Photos: (64)
Welcome to the site dieseltruckman. There is the Ford Motorcraft Cetane Booster as well as Dieselkleen and Stanadyne and probably other products out there that claim the same. Your Ford parts department manager ought to know about the Motorcraft Cetane booster. If not, time to find a new dealer.
Some people swear by them others don't. Personally, I add 2stroke oil (TC-3W) to my fuel to lube the injectors and swear by it. Others here think it harms my engine but I firmly believe it runs better so do a lot of other guys who do the same. It's all subjective to one's own opinion.
Perhaps you may want to share the problems you're having with the engines in the forum because they might not be related to the cetane level in your fuel.
Just sayin.
2005 F250 XLT SC, LB
6.0 Torqueshift 3.73LS 4x4 T/C
Trk Bld: 02/05/05 KY
Eng Bld: 02/03/05 Indianapolis
2825 Hrs +/-, 101K Miles - No Major Probs other than brakes
DC Power 185 Alternator
ZOODAD, SEIC,
Atlas 40 FICM @ 90K
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Duratrac's
Centramatics
Bodiak Front Receiver
SG2
Coolant Filter
HFCM Plug Upgrade
FP Gauge
Zerex Red ELC
Band_Member is offline
post #3 of 20 (permalink) Old 04-13-2011, 07:41 PM Thread Starter
I think the problems are being caused by the egr system pluging up, I was hoping that the higher cetane would burn cleaner and prevent the egr from pluging.
2002 F250 7.3L
2003 IHC 4200 6.0L
2005 IHC 4200 6.0L
post #4 of 20 (permalink) Old 04-13-2011, 08:03 PM
Djanzen's Avatar
Ford parts has a cetane booster and lubricate improver I buy mine there all the time!
It is a clear bottle with a red lid.
2003 F250 Larait Grey/Black 3.5" lift 33" tires Bully Dog Tridog with Outlook monitor MBRP 4" ex. KC sunshine out front
Djanzen is offline
post #5 of 20 (permalink) Old 04-13-2011, 08:10 PM
Feedback Score: 2 reviews
Yes as Band Member said others will work, i use the Ford cetane boost buy it by the case but will be getting it in the gallon cans next time 2 gallon cost less money than by the case and drive it like you stole it to keep the turbo and egr valve clean and working. Boy that takes the cake when Ford can't find it, it's there product.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #6 of 20 (permalink) Old 04-13-2011, 09:35 PM
dieselmac's Avatar
As long as the EGR system is there, you have the potential for plugging the valve. Cetane boost won't cure the problem but it should prolong it.
The very principle that EGR's operate on cause soot (more so than w/out an EGR) to be produced in the combustion process. This is circulated right back to the valve and plugs it up. Kinda ironic ain't it? Install a device to lower emissions that increases other emissions that ultimately kill the device. That's why the post 6.0L engines have EGR's and particulate filters (for soot).
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #7 of 20 (permalink) Old 04-13-2011, 09:37 PM
diesel kleen here since new...a lot of others here use the Motorcraft as well...do you idle them a frequently?...also what weight oil are you using?...b
03 F-250 CC LB XLT 3:73 rear/ almost stock/ early build/ 78,000 miles...03 F-250 ext cab Lariat Fx4 SB 3:73's /stock/187,000 all original injectors...FICM by Ed @FICM.COM / ScanGuage 2 monitoring the vitals...
03powerstrokeuser is offline
post #8 of 20 (permalink) Old 04-14-2011, 07:17 PM Thread Starter
I think we use 10W40, I'm going to cut any idle time that I can.
How hard is it to clean the egr system? one of the trucks is really bad, I had it out today for a short drive and I couldn't get it over 70 km/h.
2002 F250 7.3L
2003 IHC 4200 6.0L
2005 IHC 4200 6.0L
post #9 of 20 (permalink) Old 04-14-2011, 07:22 PM Thread Starter
I'd like to do an egr delete, but because these trucks are comercial vehicles they need an emission test every year. How bad would the test results be if I did?
2002 F250 7.3L
2003 IHC 4200 6.0L
2005 IHC 4200 6.0L
post #10 of 20 (permalink) Old 04-14-2011, 08:02 PM Thread Starter
I just looked at Bulletproof's website and they say their egr cooler is as good as their egr delete, can anybody support this?
2002 F250 7.3L
2003 IHC 4200 6.0L
2005 IHC 4200 6.0L
post #11 of 20 (permalink) Old 04-14-2011, 10:11 PM
Here is the how to on the EGR
Diesel Technician Society
One of the guys here in town works only on the 6.0 and that is the only parts house that he uses, but it also comes down to coolant for the long haul if you want to spend the $$$$ on coolant and flushes every 25-30k then the Ford junk will work or do it 1 time and go 300k with ELC coolant.
2 stroker
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
1700 Super Chip
3" dp-4" exhaust
Tymar Intake
post #12 of 20 (permalink) Old 04-16-2011, 12:07 PM
The Diesel Kleen and Diesel Cetane Booster, do they do the same thing or can they be used at the same time?
barrelslime is offline
post #13 of 20 (permalink) Old 04-16-2011, 12:17 PM
paintingman's Avatar
I have been using this one AMSOIL Fuel Additives and Performance Improver there all good.
Cetane makes diesel fuel burn faster for easier starts and they all lubricate The injectors
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
post #14 of 20 (permalink) Old 04-16-2011, 03:01 PM
barrelslime...Diesel-Kleen makes three products that I use...White jug for winter,Grey jug in summer...these already contain cetane booster...they also make a biocide called bio-kleen that I use, albeit infrequently...b
post #15 of 20 (permalink) Old 04-17-2011, 03:11 PM Thread Starter
What oil do you guys suggest for these engines?
2002 F250 7.3L
2003 IHC 4200 6.0L
2005 IHC 4200 6.0L
