Best oil for a 6.0L engine? - Diesel Forum - TheDieselStop.com
post #1 of 60 (permalink) Old 10-05-2007, 01:26 PM Thread Starter
I was running Rotella T 15-40 in my old 7.3L diesel. I have quiet a stock pile (bought 75 gallons at a close-out price last year for the 7.3 I had, truck totaled out by a drunk driver - now forced to buy into a new truck) One very credible diesel mechanic sais there are better oils out there for this 6.0L engine and that the right oil will make a huge difference in the longevity of the truck and reduce problems as the truck ages. Since I now own a 2004 6.0L........what oil is best for these motors?
2004 F-250 6.0L Metallic Blue. All stock
RobRob is offline
post #2 of 60 (permalink) Old 10-05-2007, 01:38 PM
Re: Best oil for a 6.0L engine?
I've had great luck with Rotella in my 2004 6.0L - it's all I've run since I had the truck. 76,000 miles now, all except for the dealer fill with Motorcraft.
2004 F-350 Lariat SRW <><
315 BFGs, Edge Platinum, ARP Studs, & B&W Goose
1998 Cherokee RockCrawler
NCfarmboy is offline
post #3 of 60 (permalink) Old 10-05-2007, 01:39 PM
OneTonHillBilly's Avatar
Rotella T
OneTonHillBilly is offline
post #4 of 60 (permalink) Old 10-05-2007, 01:45 PM
JIM_C's Avatar
My Photos: (5)
Congrats on the 04 and that's too bad about your old truck. I hope nobody was hurt or killed by that idiot's decision to D&D. Let me start by saying opinions are like... well, everybody has one. The 6.0 is tough on oil but I think the Rotella is fine as long as it's rated properly. Look in your manual to see whether you need CH-4, CI-4, etc. Some people have reported finicky 6.0s that run better on 10W-30. In Michigan, you might consider this in the winter. If the Rotella is properly rated then run it and get an oil analysis done at 5k and see how it goes. You might get an oil analysis done anyway to see what's going on in your new-to-you truck.
You can also check out this thread.
2014 F250 Platinum CC Short Bed 4x4, 6.2 (I Got Gas Now!)
2003 F250 XLT CC Long Bed 4x4, 6.0 w/Auto (SOLD)
JIM_C is offline
post #5 of 60 (permalink) Old 10-05-2007, 02:25 PM Thread Starter
My manual recommends CI-4. CH-4 is also acceptable. The oil I have tons of is: meets API service CI-4, CH-4, CG-4, CF-4, CF/SJ, SL Now that is all greek to me, but I believe it will work
RobRob is offline
post #6 of 60 (permalink) Old 10-05-2007, 02:25 PM
You need an oil that also has hydraulic properties to account for the high pressure systems used by the 6.0. Motorcraft and International's oil meet this requirement because they build the truck/engines that need it.
Think of a floor jack. If you put motor oil in it, it won't work. Same issue with the 6.0L (and 7.3L to a lesser degree). Without hydraulic properties, the oil does not work as well with the high pressure systems.
thelogster is offline
post #7 of 60 (permalink) Old 10-05-2007, 02:31 PM Thread Starter
You make a very good point, but I don't see anything in the manual referencing the hydraulic properties.
RobRob is offline
post #8 of 60 (permalink) Old 10-05-2007, 03:17 PM
well guys i feel it is all personal preference as long as it is ch 4 approved you are ok cause it all comes out of the ground beneath us i have seen so many threads on what oil is the bes they all need changed and all need filtered but remember it all comes from a hole in the ground as long as it meets oem specs you are cover buy the oil company
2011 f 350 lariat crew cab dually. Loaded to the nines
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2012 POLARIS 550xps SUNBURST ORANGE
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
post #9 of 60 (permalink) Old 10-05-2007, 03:19 PM
oh ya my personal preference in canada here is petrocanada duron 5w40 or lucas 15w40 CHEERS GUYS
drford is offline
post #10 of 60 (permalink) Old 10-05-2007, 03:33 PM
im running amsoil oil ame 15w-40 & filter eao88 good for 25k mi changes
07 f250 6.0l xl sc 4x4 43000mi Bone Stock
Amsoil Authorized Dealer
armygunit is offline
post #11 of 60 (permalink) Old 10-05-2007, 04:31 PM
There are probably better oils for the 6.0 but Rotella T is perfectly fine so long as you change it regularly. Main thing is to detemine how long it'll hold viscosity without shearing down, then set your OCI accordingly. Get an oil analysis or three, or look around for some oil analysis threads on this site that'll give you that info.
2004 F-250 Lariat CC, Short Bed, 4x4, 6.0L, TorqShift, FX4, Metallic Green/Arizona Beige, Medium Parchment Leather, Fumoto, B&W Turnover, A.R.E. LSX Tonneau, Built 4/01/04
MoeB is offline
post #12 of 60 (permalink) Old 10-05-2007, 05:55 PM
Now that's a crock of crap!
On edit, I would say that any fluid has "hydraulic" properties. A floor jack will work with water or motor oil. Hydraulic oil is simply oil with a little different viscosity and a different additive package. NO detergents or dispersants.
Maybe an anti-corrosive additive and an anti-foam.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 251,000 miles. Uses no oil between changes.
montanafan is offline
post #13 of 60 (permalink) Old 10-05-2007, 06:43 PM
darsey715's Avatar
How many are using delo? How do you like it and have any of you compared it to rotella? thanks.
2003 6.0 f250
darsey715 is offline
post #14 of 60 (permalink) Old 10-05-2007, 06:48 PM
Over the years, we have had MANY oil threads, and the general consensus of opinion is that the 6.0 is a picky engine, and one will like Rotella, the next one maybe likes Delo better, but they are both great oils.
post #15 of 60 (permalink) Old 10-05-2007, 06:48 PM
Ive been rubbing Delo since the first change. 30000 later and no problems, changed every 5000.
uzi556 is offline
