BG Diesel additives? - Diesel Forum - TheDieselStop.com
Old 10-29-2009, 08:19 PM   #1 (permalink)
F250crazy's Avatar
Anyone ever use BG diesel products? If so any good comments? Bad comments?
F250crazy is offline
Old 11-01-2009, 07:56 AM   #2 (permalink)
F250crazy's Avatar
Bump thought I would try again.
Old 11-02-2009, 12:31 PM   #3 (permalink)
DizzyD's Avatar
Crazy, not sure who BG products is... guess I'll plug it in google and see what I learn.
Only* thing I add to my fuel is 16OZ of outboard motor oil for every 30 gal diesel. I noticed quieter operation immediatly. Took my wife a while, finally she asked if I had done someting to the truck as it runs quiter inside. Only reason I'm doin it is after reading /research is to help boost whatever lubricity is left in the ULS fuel.
* when it get s down in the low single digits I'll add Power Service anti-get, CETANE booster in the white bottle.
2006 F-250 XLT FX4 PSD 6.0, Born in Kentucky 10/05. 4X4 Crew, auto, 3.73, Tow Command, Dark Slate Gray, Oil Guard bypass filtration system and Cyclops no-Start.
*2012 BOSS 302, Blaze Yellow
*1993 F250 4X4, 5.6L farm truck
*2008 Polaris Sportsman 500 HO X2
DizzyD is offline
Old 11-02-2009, 12:34 PM   #4 (permalink)
DizzyD's Avatar
anti-gel = what I ment to say.
DizzyD is offline
Old 11-02-2009, 04:52 PM   #5 (permalink)
MikeL46's Avatar
My Photos: (14)
BG - Barry Grant? Big in drag racing circles, not well known outside of that. But, I didn't know they did any additives.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 11-02-2009, 07:47 PM   #6 (permalink)
F250crazy's Avatar
In Virginia BG products are very big here. They sell intake cleaners, trans flush kits, oil additives ect. BG Company · Cached Try this web site and click on diesel products.
