Bg Trans Filter Of Cleaner - Diesel Forum - TheDieselStop.com
Old 07-02-2009, 04:57 PM   #1 (permalink)
This Is For Ford Trans Techs I Had My Trans Serviced The Other Day And On The Bill It States Bg Trans-trans Clean Is The This A Filter Kit Or Cleaner This Truck Has Two Filters Can Anyone Shed Any Light On This
2005 F350 XL REGULAR CAB 6.0 11 FOOT SERVICE BOX DRW STOCK 212,347 ON THE CLOCK
1997 34.5 FLEETWOOD AVION 5TH WHEEL
2003 F350 XLT CREW CAB 7.3 STOCK DRW 85,000 on the clock
JOHN 3:16
timbo2 is offline
Old 07-02-2009, 08:15 PM   #2 (permalink)
Supporting Member
my03psd's Avatar
The BG is a cleaner/additive they put in w/a tranny flush.I believe the internal filter is a metal screen that only need to be replaced after so many miles, say 100k.The external filter is the on that looks like a litle roll of toilet paper and the manual says to change this filter every 30k miles.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 07-02-2009, 08:28 PM   #3 (permalink)
SO I SUPPOSE IF THEY DID NOT CHARGE ME FOR THE FILTERS THEY DID NOT CHANGE THEM DO YOU HAVE TO DRAIN THE FLUID TO CHANGE THE EXTERNAL FILTER (THE ROLL FILTER)
JOHN 3:16
timbo2 is offline
Old 07-02-2009, 08:28 PM   #4 (permalink)
69cj's Avatar
Try every 15,000 miles. The internal stops trees and boulders and needs to be replaced during a tranny rebuild. tranny needs a flush every 30,000 miles
69cj is offline
Old 07-02-2009, 08:53 PM   #5 (permalink)
Supporting Member
my03psd's Avatar
It says the first change at 15k, then 30k, then every 30.F-350 Turbo Diesel General Maintenance Schedule
my03psd is offline
Old 07-02-2009, 08:55 PM   #6 (permalink)
Supporting Member
my03psd's Avatar
You don't have to drain the fluid to replace the external filter.Just loosen the housing and replacethe filter you lose about 8oz. of fluid.
my03psd is offline
Old 07-03-2009, 01:12 PM   #7 (permalink)
69cj's Avatar
Go ahead and change your ext. tranny filter every 30,000 if you like. It's your tranny and your money.
69cj is offline
Old 07-03-2009, 04:36 PM   #8 (permalink)
Supporting Member
my03psd's Avatar
Wow!! OK, hey just stating what it says in the manual.I actually change mine @ 15k but some people stick to excactly what the book says, not trying to start a pi$$ing match.
my03psd is offline
Old 07-03-2009, 06:13 PM   #9 (permalink)
69cj's Avatar
Not trying to argue! The 6.0 and torqueshift can be a dynamite drive train. They do however require proper maintenance and will let you know if you don't do it. That reminder can be very expensive.
69cj is offline
Old 07-04-2009, 12:40 PM   #10 (permalink)
Supporting Member
my03psd's Avatar
I agree 100%.More people would have less problems if they did follow their maintenence correctly.
my03psd is offline
