Bleed air from fuel system - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 08-08-2007, 12:11 PM Thread Starter
cut7's Avatar
What is the proper procedure for removing air from the fuel system? I know the system is supposed to bleed itself, but that doesn't seem to be the case. Hopefully the techs will chime in here.
Also, where is a good dealership in north San Diego county? I would like to get the inductive flash (to replace the buzz flash) but all the dealerships I have gone to are giving me grief about it.
Regards,
Tom
2006 F-250 CC 4WD King Ranch
2005 Excursion 4WD
cut7 is offline
post #2 of 9 (permalink) Old 08-08-2007, 01:45 PM
FamilyRide's Avatar
Re: Bleed air from fuel system
If fuel is moving through the system, air will purge.
What makes you think you have air in the fuel system?
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #3 of 9 (permalink) Old 08-08-2007, 04:47 PM Thread Starter
cut7's Avatar
Poor mileage, & air at the back of the heads has no where to go. That's why people make regulated returns.
2005 Excursion 4WD
cut7 is offline
post #4 of 9 (permalink) Old 08-08-2007, 06:03 PM
weasel79's Avatar
The air might get trapped temporarily but it will work its way out. Only way that air would make bad fuel mileage is if there was a leak before the fuel pump and sucked in air.
2003 F-250SD XLT X-Cab short box March 03 6.0L Torque shift, manual 4x4 superwinch hubs, 121,000 miles,315/75/16 BF Goodrich mud terrains, autometer boost/fuel psi/tranny temp, AFE 4" straight pipe,
weasel79 is offline
post #5 of 9 (permalink) Old 08-08-2007, 06:34 PM
FamilyRide's Avatar
...and aeriated fuel is a little different if that's what it is. But we all deal with that to a point. Some spend a lot of $$$ on Air Dog etc. but I'll say it again, I can't see it being worth the money.
post #6 of 9 (permalink) Old 08-09-2007, 12:47 PM Thread Starter
cut7's Avatar
You don't think the airdog helped with mileage?
2005 Excursion 4WD
cut7 is offline
post #7 of 9 (permalink) Old 08-09-2007, 04:50 PM
Not for the costs involved.
OMCUSNR is offline
post #8 of 9 (permalink) Old 08-09-2007, 11:54 PM Thread Starter
cut7's Avatar
Did you see an increase in mileage?
2005 Excursion 4WD
cut7 is offline
post #9 of 9 (permalink) Old 08-10-2007, 10:52 AM
FamilyRide's Avatar
A 2 MPG increase would be awesome and really optimistic. Now calculate how much money that saves you over time. How long to recoup the cost of something like an Air Dog? Same deal with tuners, exhaust etc. For some it may be worth it, for most it won't be.
