Plan on taking my truck up north this winter. Living in FL I've never had to use the heater plug. I was wondering at what temp do you guys start pluging in your engines?
I did at 20 degrees or less with my other deisels and plan to do the same for my 6.0 I have a heavy duty timer so I can have it come on 5 hours before I need the truck.
...then you have the guys from -0 climates posting about not needing to use a block heater at all. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
__________________ 2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
Mine sits 10-12 hours at work at 0 and starts right up.......................
95 F350 CC PSD 5SPD Gear Vendors O/D 4x4
92 Explorer Eddie Bauer
05 Expedition 4x4 5.4 3 valve.
Former trucks:
2003 F250 CC 4x4 6.0 HEADACHE! Traded before it blew!
89 F250 2wd 7.3 5spd with 256K when sold
94 F250 4X4 IDI Turbo 7.3 5 spd 160K when sold
95 F250 S/C 4x4 PSD 5 spd with 146K when sold
00 F250 C/C 4X4 PSD 6 Spd with 126K when sold (180K now)
So does mine, but only because I have no means of plugging it in. Given the choice, I would plug it in to reduce engine wear and warm up time. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img]
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
I have the remote start on mine. I can start mine from up to 2500 feet away. That gives me about 5 min of run time before I hit the truck. The engine temp is just about ready to move by the time I get ready to put it in drive. I also spend winters with temps 20 or less quite often and I've never plugged mine in. I think good glow plugs will make the difference there.
99' F-350 PSD, 4X4 CC LWB, AUTO, TRANNY COOLER, TRIPLE A PILLAR, TRANS TEMP, PYRO AND BOOST, AUTOMETER SPORT COMP GAUGES, 4" DPPI TURBO BACK EXHAUST, AFE STAGE 2 INTAKE, DVD TV ON CEILING, TONNEAU COVER, PRODIGY BRAKE CONTROLLER, COMMANDO FM-870 REMOTE START AND ALARM, 2 INCH LEVELING KIT, RUNNING BOARDS & MUD FLAPS, TOYO 33 M/T ON 18 X 9.5 RIMS
Have you heard the term "wet stacking?" Letting your truck idle in cold temps is very detrimental to internal parts. I used to do it, too. It's convenient to get into a warm truck, but not worth the damage it does.
To the original poster- If your truck is '05 or later you better make sure you HAVE a block heater, as this item ceased to be present on newer trucks unless it was ordered. I have also heard that trucks came with a heater and no chord. This would be more likely if the truck was purchased in FL. As for your temp question- I try to get mine plugged in under 30. Sure, your truck will probably start at zero without plugging it in, but I have often times likened the first five minutes of engine operation to kicking your best friend in the face. The racket can't be good for the engine.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
Yes, but there is a huge difference between sitting during the day and overnight. My 6.2 Chevy would start just fine after sitting at work but would balk at sitting overnight without a plug in. I think it is way easier on the components to be warmer than 0 degrees when you start it. Just think of what even 5-30 oil is like at 0 degrees.
I live in Southwestern PA and this will be my first winter with a Diesel and i'm planning on not using my block heater this winter.We get some pretty cold winters, but i'm gonna try it and see what happens anyways.
But if the need to plug it should arise I will just have to use an extenion cord and plug it in the garage for the time being and in the spring figure something out and have to set something up for next winter in this spring.
2004 F-250 (FX4) 4x4 XLT Crew Cab Short Box with a "6.0L Powerstroke Turbo Diesel".All stock.
The Difference between men and boy's are the size of there toys.
My Daily Driver is a 99 Nissan Altima 4 door.
Sounds great in theory but you guys are talking about some pretty mild temperatures.
I would love to be able to hop into the truck and take of in 30 seconds but I think the damage would be much more severe than wetstacking when the temperature is -40. At that temperature it takes the truck about 5 minutes to calm down and stop the racket even when plugged in.
I have heard many different guidelines to go by. The recommendation I use, regardless of diesel or gasoline engine, is to plug in when the temps hit 5 degrees. I use a timer and will adjust between 2 and 4 hours depending on how cold it will get.
2003 350 Lariat FX4 Short Box 6.0L *SOLD*
2008 FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
2007 Keystone Raptor 3712TS PICTURES
There is nothing to setting up an intermatic timer. You just plug the timer into the wall socket. Mount the timer with a screw, set the timer and your're done.
