Block heater- Plug it in for 1hr or all night - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 01-24-2008, 11:27 PM Thread Starter
New to the forum was wondering if i should leave my truck plugged in for 1hr or all night. Does it make a diffrence?
xtremekustomz is offline
post #2 of 16 (permalink) Old 01-24-2008, 11:50 PM
Depends on how cold it is. Most guys find a timer that'll handle 15amps & 1500 watts & set it for 3 hrs before they leave. That's pretty good down to minus #'s. Leaving it on over night is pretty much overkill & runs your electric bill up needlessly.
OMC
OMCUSNR is offline
post #3 of 16 (permalink) Old 01-25-2008, 08:46 AM
G BURDICK's Avatar
I plug mine in for at least 3 hrs before I leave and up to about 5 hrs max with a hd timer. Usually when it is 20F or lower.
MINE
2001 F350,XLT,CC,4x4,PSD,6-SPD,SRW,156"WB,OFF-ROAD,LS,PTTTM,AIC,PRODIGY P3 BRAKE CONTROLLER,BILSTEIN SHOCKS,TOYO OPEN COUNTRY A/T,HAWK ROTORS AND HAWK LTS PADS,PML REAR DIFF COVER,RHINO LINING,GARMIN NUVI 2595LMT,SIRIUS RADIO,TRUE BLUE
2006 F350,XLT,SC,4x4,6.0L,TORQSHIFT,SRW,142"WB,FX4,LS,E SOF,TOW
COMMAND,UPFITTERS,LINE-X,WEATHERTECH MATS,COOPER DISCOVERER AT3,GARMIN NUVI 1350T,DARK GREEN SATIN W/SILVER
HERS
2009 EXPEDITION EL,LIMITED,4WD,WHITE PLATINUM TRI-COAT,BLACK INTERIOR,DVD,MOONROOF,POWER DEPLOYED RUNNING BOARDS,MOONROOF,WEATHERTECH MATS,GARMIN NUVI 265WT
G BURDICK is offline
post #4 of 16 (permalink) Old 01-25-2008, 09:01 AM
Red face
I plug mine up when I come in for the night and unplug it when I leave the next morning. Do not notice the elect. bill going up?I like the ideal of the timer, might have to try
'04 F250 CC Lariat 4WD SWB 6.0L 105k
Bullydog Triple Dog Downloader
AEM Intake Brute Force
'02 Saturn VUE (wife's)
'86 Mazda only 114k
Rkimmel is offline
post #5 of 16 (permalink) Old 01-25-2008, 12:54 PM
stevedunham's Avatar
My Photos: (6)
I've done both, all night and timer... It's been below 0 overnight for the last 3 - 4 weeks where I live in Colorado so I use my block heater almost every night... The wife b*tched about the electric bill so I recently put it on a timer set to come on at 3:30 AM for a 6:30 AM starting time... Seems to work just as well as leaving it on all night and shouldn't have as much impact on the electric bill... The block heater uses a considerable amount of juice to operate apparantly...
** SMD '04 F250 6.0 CC King Ranch, '14 F350 6.7 Lariat CC **
Original engine grenaded @ 31,000 miles..! Replacement engine DIY bulletproofed, Gen 4 Injectors, 58V FICM, Blue Spring, IPR Remote Oil Cooler/Coolant Filter, ARP studs, DC Power 270 Amp Alt, BD billet H2O pump, CCV catch can, MBRP Duals, 2 blown Turbos currently running a Garrett, DR Edge 8.5" hybrid lift w/ 5" rear leafs, 37x13.5x17 Swamper M16's, Draw-Tite portable winch mount, WARN xD9000i, WARN Pocket Flares w/ Durabak, 4.56's w/ F&R ARB's, Dynatrac Dana 60 35 spline stubs, Powerslot Cryos/Hawk LTS, Yukon Hardcore 35 spline hubs, 2" wheel spacers,
stevedunham is offline
post #6 of 16 (permalink) Old 01-25-2008, 03:29 PM
Banned
I use an Aube timer. It has an adjustable automatic photocell mode and an automatic temperature sensor mode. Plus all the manual and timer setttings.
Aube Technologies
Gooch is offline
post #7 of 16 (permalink) Old 01-25-2008, 08:26 PM
You will need 3 HRS for it to be effective. Don;t expect it to blow hot air out the vents though.
My Rigs:
86' F-250 XLT Lariat,6.9 Diesel, Extended Cab, 4x4, 4.10's, 8'bed, Push Button Glowplugs, etc...
99' Crown Vic Police Interceptor (P71) w/Steet apperance package, 4.6L, 4R70W, 3.55 Trac-Loc Differential (DK), Total Cloth Interior, New Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 110K,
04' F-150 XL Heritage, 4.6L V8, 4x4, Ext Cab.
Fordiesel69 is offline
post #8 of 16 (permalink) Old 01-26-2008, 10:19 AM
I plug mine in whenever it's parked but it's much colder up here. The Marinco mod makes it much more convenient too
2003 F-250 FX4, Super Cab, Long bed Grey. 6.0 Automatic, Spray on Liner
davidg5252 is offline
post #9 of 16 (permalink) Old 01-27-2008, 02:24 PM
IIRC, the block heater is 1500w, which is like running a hair dryer all the time, or 15 100w lightbulbs. Or 5 average home computers. 7 laptops. You get the idea.
We use a digital 5000w timer, set to come on 3 hours ahead of our leave time. My wife's van and the X get plugged in, and no problems with that set up.
2005 Eddie Bauer X -- all stock.
Wren is offline
post #10 of 16 (permalink) Old 01-28-2008, 07:14 AM
OneTonHillBilly's Avatar
I have a 15 AMP dial type timer I bought from Home Depot for $20. I leave at 6 am so I have it turn on at 2am. I always plug it in. Warm up time is 5 minutes instead of 20 mins.
OneTonHillBilly is offline
post #11 of 16 (permalink) Old 01-28-2008, 01:09 PM
Rare occurrence here last night - 4" of snow. Temp about 26f. Not plugged in, original batteries, got in turn it on, waited for the fuel pump to stop, turn it over & fired right up. 5 mins of shoveling snow off the window, & off we go. No romps, stumbles, grumbles or *****ing - 4wd all the way to work 35 miles up I-5 @ 45. No problem.
OMCUSNR is offline
post #12 of 16 (permalink) Old 01-28-2008, 03:03 PM
I usually park my truck in the garage, but last night it had to sleep outside. It was -30C (-22F) overnight. I though this was a good time to test it. After plugged in 1 hour it didn't start. I probably could have cranked it longer and got it to start. After 2 hours it started right up and ran smooth. 2-3 hours is definately enough plug in time.
2003 F-350 Lariat crewcab 4x4, 266,000kms, Ed's FICM c/w Atlas 40 and MBRP 4" turbo back exhaust.
2004 F-350 Lariat crewcab 4x4,259,000kms, ARP studs, EGR delete. (Sold)
1996 E-350 12 passenger 360,000kms (SOLD)
cruiserheads is offline
post #13 of 16 (permalink) Old 01-28-2008, 03:05 PM
Four hours whenever it drops below 0f (-18c or so) is my rule of thumb.
Regards
George Marchewa
2003 F250 4X4 Lariat FX4 Supercab SB 6.0/Auto
2006 Keystone Cougar 276EFS 5th Wheel
2012 Mustang 3.7 Premium Pony Package
Penhall is offline
post #14 of 16 (permalink) Old 05-29-2008, 06:40 PM
I cant find mine ANYWHERE!! 06 f-350 any clues as to where the *$@%@(* it is LOL
removed my owners manual too and cant find it either, nothing like organization eh?
tregrad is offline
post #15 of 16 (permalink) Old 05-29-2008, 11:40 PM
Look for the plug to be wire tyed just over and buried above the passenger side tow hook. If no luck there, crawl under the truck and look just above the starter at the block heater itself for a cord attached. If nothings there, then yours is one of the trucks that got delivered (depending on states deliveded to) without the cord. If you want one you will have to purchase it and install it yourself.
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
Similar Threads
Block Heater Plug CapeCodder '99 & up 7.3L Power Stroke Engine and Drivetrain 1 12-18-2007 11:05 AM
Block heater plug Richman 6.0L Power Stroke Engine and Drivetrain 6 11-15-2006 05:18 PM
Is your block heater plug hard to plug in... olddieseldude General Diesel 10 02-10-2006 11:01 PM
Odd thing happened last night...block heater issue. Powerstroke2000 Power Strokes 1994-1997 General 8 12-09-2005 08:41 AM
block heater plug boaterholic Power Stroke Excursions 17 12-27-2003 08:59 AM
