block heater working - Diesel Forum - TheDieselStop.com
Old 12-09-2006, 02:31 PM   #1 (permalink)
Hi I just installed my block heater cord and was wondering how do I know if it's working? I pluged it in for about an 1 hr 20 mins and I didn't see much difference. Also on the plug into the block there is a small brass or copper piece that I didn't notice which way it was bent when I unpacked it. Is it suppose to be bent in between the 2 holes or bent to the outside. If you look at ebay #250056744353 the metal piece is bent out, does it matter because I bent it in between the 2 holes.
SimonCX is offline
Old 12-09-2006, 02:47 PM   #2 (permalink)
Re: block heater working
Go look at you power meter before you plug it in.
Look at the power meter after plugging it in.
If the meter is moving faster after you plug it in, its working.
OMCUSNR is offline
Old 12-09-2006, 02:48 PM   #3 (permalink)
The copper piece is to ensure a proper ground. By routing it between the two holes, you are getting very close to shorting it out to one of the hot leads. If it's working, you should be able to feel some heat near the heater on the block after an hour.
2003 F250 XLT Sport Ext Cab ESOF FX4 6.0L TorqShift, Sonic Blue/Black Leather.
BrakeSmart Trailer Brake controller.
Leer Cab high Browning Edition Cap.
2004 SunnyBrook Solanta 28' TT small slide 7800#
35 Years in the trenches!
Retired Machinist & Manufacturing Engineer for fuel control systems for very large Diesel Engines. Locomotives to Super Tankers.
Designed and trouble shot manufacturing processes for stuff from Design Engineers. Sometimes had to wrestle for design changes.
Designed and built tools and equipment to machine, assemble, disassemble, repair and test.
Wisdom comes with age, but sometimes age comes alone.
"Nothing is FOOLPROOF because fools are too ingenious"-Mark Twain
johnmart is offline
Old 12-09-2006, 03:14 PM   #4 (permalink)
Thanks I changed it, pulled out the plug and put the copper piece to the outside and put electrical grease to make sure it gets good contact. Is it suppose to make noise when it's pluged in or is there anywhere that I can touch to see if it's working.
SimonCX is offline
Old 12-09-2006, 03:46 PM   #5 (permalink)
If it is really quiet, I can usually hear mine starting making some noise within a few seconds after plugging it in. You'll probably need to plug it in for at least 3 to 4 hours to get much benefit from it.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
Old 12-09-2006, 06:28 PM   #6 (permalink)
"Anyone got any suggestions for the coolest (safest) car seat?"
Just one suggestion.
Put the car seat in the CENTER of the back seat.
A friend lost a child in a car seat on the passenger side of the back seat when they were hit.
johnmart is offline
