blown headgaskets and upgrading - Diesel Forum - TheDieselStop.com
Old 11-01-2009, 12:23 PM   #1 (permalink)
parttime's Avatar
as some of you already now my truck has a blown head gasket.i am going to go ahead and do headstuds with black oynx gaskets, new oil cooler, coolant filter, and the permanent egr fix while in there.is there any thing else that i need to replace or upgrade while in there?
1997 F350 CC 4x4,4" MBRP Turbo back Exhaust,DIY Intake,DP F5 Tunes,Suncoast tranny & triple disk converter
1996 F250 ex cab. 4x4 4" MBRP Turbo back Exhaust,Tymar intake,DP Tunes,6" Skyjacker an 36" Nitto MG's,BTS tranny & Stallion converter
2003 F250 ex cab FX4 ARP head studs,SCT,4" MBRP Turbo back exhaust,ATS tranny & triple disk conveter.
parttime is offline
Old 11-01-2009, 03:03 PM   #2 (permalink)
Strokin' 6.0's Avatar
Well, if you haven't done it already, you might as well put in the new and improved turbo oil drain line, since the turbo is going to be off anyway.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Strokin' 6.0 is offline
Old 11-02-2009, 10:56 AM   #3 (permalink)
parttime's Avatar
is there a certain year line to change over to or is it aftermarket?also read last night on another forum about a ccv mod, what is that?
parttime is offline
Old 11-02-2009, 01:18 PM   #4 (permalink)
teamroper60's Avatar
Here is the return line part number: 6C3Z-9T515-A
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 11-05-2009, 09:22 PM   #5 (permalink)
parttime's Avatar
what should the headstuds be torqued at?
parttime is offline
Old 11-05-2009, 10:15 PM   #6 (permalink)
IIRC, ARPs are to be torqued three times. The first to something like 80ft-lbs, the second to 160ft-lbs and the final to 245ft-lbs. I don't know the specs for the H-11 studs but I seem to recall them being a little lower.......
pics
#43
Old 11-06-2009, 07:40 PM   #7 (permalink)
Have you thought about head coolant lines to help keep the heads cool.
I put them in when I had my studs done. Not to much $ 150.
work&play is offline
