blows white smoke... - Diesel Forum - TheDieselStop.com
Old 04-01-2007, 07:37 PM   #1 (permalink)
My Photos: (5)
My buddys got a 05 6.0 and it blows white smoke at idle and even worse when you rev it up. What is the problem? I think it might be a blown head gasket leaking coolant into the cylinder? Its got 40k on it and its already blown one head gasket and it was replaced, so i thinking it might be the same problem.
thanks!
2002 7.3 powerstroke diesel lariat, automatic, crew cab, long wheel base F-350 SRW. 35" mud brutes, 6" procomp lift, custom tool box, 5" smoke stacks, brush guard and an oil leak <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
yamahajo is offline
Old 04-01-2007, 08:32 PM   #2 (permalink)
Re: blows white smoke...
What all has been done to the truck? Mods? Climate? How's it run?
OMCUSNR is offline
Old 04-01-2007, 10:22 PM   #3 (permalink)
My Photos: (5)
it had a chip in it (idk the brand) but it was taken out when the new head gasket was put in about 3k ago. Its got a 4" exhaust and 5" stacks and thats all the mods oo its got a 12" lift and 40" tires if that matters...that motors under a load rollin them around town! We live in Baton Rouge LA, so its hot and humid. I havent driven it since it started actin up, so idk how it drives. Im just trying to point the owner in the right direction.
yamahajo is offline
Old 04-02-2007, 11:44 AM   #4 (permalink)
With whats been done to it, I'd take it to a local independant diesel tech, and have ARP headstuds intalled along with new gaskets on both sides. Maybe look at firerings.
OMCUSNR is offline
Old 04-02-2007, 02:30 PM   #5 (permalink)
White smoke could just as easy be a blown ERG cooler.
RoyC
2005 Limited, 6.0L PSD, 4X2, Mineral Gray, 3.73 LS. Excursion Build date 02-08-05 6.0L 2005MY Engine Build date 01-03-05 Huntsville, Ala.
2005 50th anniversary Thunderbird Red with all
options except hardtop.
Old Ride: 2003 Excursion 6.0 L March 2003 Build 73,000 with no significant issues.
RoyC is offline
Old 04-02-2007, 07:12 PM   #6 (permalink)
My Photos: (5)
i keep forgetting, but i need to check the radiotor and if its low, then its got be be a head gasket. so ill do that tomm.
yamahajo is offline
Old 04-03-2007, 12:22 AM   #7 (permalink)
and... regear the differentials, if he hasn't already.
2005 F250 PSD Lariat 4x4 FX4 3.73, MBRP 4" turbo-back
ISSPro EGT and Tranny
Oilguard Bypass
SCT Tuned by Innovative
ryandye is offline
